broke valve spring
Old Oct 7, 2006 | 08:53 PM
mike2244's Avatar
Default broke valve spring
i bought the lloyd elloit LT1-LE1 package about 7000 miles ago. the car was running great and he does really good work. but i got a ticking noise and a miss then the car made a pop and it seized the motor. i pulled off the valve cover and found a broken valve spring. what would cause the valve spring to break?
Old Oct 7, 2006 | 08:59 PM
96capricemgr's Avatar
By "seized" you mean dropped the valve into the piston jambing things up right???
Old Oct 7, 2006 | 09:01 PM
Ironxcross's Avatar
revving too high before its broken in?
Old Oct 7, 2006 | 09:34 PM
speed_demon24's Avatar
Do you have the CM612 springs or comp 918's?
Old Oct 8, 2006 | 06:51 PM
mike2244's Avatar
i think that they were stock springs.
Old Oct 8, 2006 | 06:55 PM
mike2244's Avatar
and for all the butt hurt people out there i am not saying it was lloyd elliots fault at all. he does awsome work and would recommend him to everybody. i just want to find out what caused the problem so it wont happen again. the only reason i used lloyds name is to let everybody know what set up i am running so that i didnt have to list all my mods.
Old Oct 8, 2006 | 06:57 PM
mike2244's Avatar
yes it dropped the valve and jammed things up. in hope to pull the heads off this week and see what all damage it caused. it just might be time to go with a stroker motor.
Old Oct 8, 2006 | 08:38 PM
Schweet97Z's Avatar
the stock springs is what did u in.....why would you use stock spings with a higher lift cam?
Old Oct 8, 2006 | 08:56 PM
vanilla89's Avatar
lloyd dont use stock springs,it's the 612 spring adn i'v heard of them breaking befor
call lloyd and he'll fix you up
Old Oct 9, 2006 | 01:36 AM
mike2244's Avatar
cool i thought they were stock springs because the website dont mention spring replacment. i will give him a call
Old Oct 9, 2006 | 09:13 AM
2fast97Z's Avatar
stock springs with cam/heads=retarded get some beehives or somethin man
