AC Removal Finished
This is what I did. I cut the Box inside of the Fire Wall line, and ended up with this.
Every hole to bolt in the Heater Core and Blower Motor is still intact, and fully functional. The next thing I did was cut a panel out of Aluminum, and bolt it in place. Holes were cut out for all necessary stuff. This is the finished project.
I looked at my spare heater/ac box and stuff last night and I am certain your setup won't work. Hopefully no one else ran out and hacked their boxes up thinking they'd be able to retain heat.
If I am wrong, please explain how your setup will work. I just don't see it.
Trust me, I looked at it very closely before I cut it apart. I have no way to test it obviously, but everything is still factory intact.
I'll find out when I get it running soon, and let everyone know.
Keep us updated on what the outcome is after you get your car running again. This might be potential "Appearance Hall of Fame" material.
www.frrax.com
I dug out my stuff again and I am 100% positive your setup will not work. Leaving all the heating stuff is fine and great but that trap door occurs on the car side, after the air has passed through the AC coil and that box that's in the bay.
the green square i put on your pic is the same area that you see the arrow going through in the pic above. You will not have airflow to your vents, you removed the path and blocked it off.
