how do i know what gears i have
Old Oct 11, 2006 | 10:02 AM
93Zdriver's Avatar
Default how do i know what gears i have
i have 2 93 camaro z28s, one has a rearend change so im not worried about that one. I heard that the gear shifter will tell you, mine reads prnDd21, i routinely averaged 19 or 20mpg between highway and city, but about 70% of my driving is interstate. I was really wondering. I read something about it say gu2 or gu5 on the inside of the door, but i didnt see it.
Old Oct 11, 2006 | 10:06 AM
Razor_Blade's Avatar
With the age of our cars and the frequency of rear end failures, the only way to be sure is to count the teeth. That is unless you are the original owner.
Old Oct 11, 2006 | 10:33 AM
BlazerINtheWork's Avatar
sure way to tell with the cover off
prolly wouldn't hurt to change the fluid anyways
Old Oct 11, 2006 | 05:33 PM
93Zdriver's Avatar
just put royal purple in a month ago
Old Oct 11, 2006 | 07:01 PM
infinitebird's Avatar
You don't have to do that.
Just get on the highway and see what RPM you're turning at a steady speed. It's quite easy to figure out from that.
check this: www.f-body.org/gears
Old Oct 11, 2006 | 07:12 PM
anaik's Avatar
On a '93 the RPO sticker should be on the inside of the glovebox lid. But like was said, that will be what was installed at the factory. Use the calculator in the above link.
Old Oct 11, 2006 | 07:31 PM
the_merv's Avatar
Veteran: Air Force
Look in the Glove Box for the hell of it and let us know what it says... If you have 1st on the Console, probably GU5 code, which is the 3.23's.
