le2 track times
I would assume with the required bolt-ons for the le2 heads and le3 cam, i would think the car would at least be a low 12sec. car correct? I know every car is different but my car with bolt-ons now will run with a high 12 sec. car as it sits in my driveway as i write this.............. so le2 heads, le3 cam should dam well make it run low 12's.
They are 2.055/1.60 valves.
Here are the flow #'s . . . . . . .
.2 143/110
.3 198/143
.4 243/171
.5 274/184
.6 284/196
.650 287/201
Lloyd Elliott
972-617-5671
Eportworks.com
Just got to put engine together.
You can definitely make power with ported stockers and 2.00/1.56s as this had already been addressed and you don't need a huge cam either..You'd laugh at how small my cam is, but its matched to the heads, to the gear, and to the converter...I don't have massive weight reduction, I'm around 3600 with me in it..
Suspension set up is simple also...The regular bolt on stuff set up the right way with stock springs and shocks and on M/T Drag Radials..
If you want I'll pm you my whole "shebang" as I have no secrets its all about the fun...I'm by no means an expert, but what I have works well and is fairly simple...
--Alan
--Alan
"Taubr" your already got you're suspension set up that's a plus. 11's should be easy with fully ported stockers and the right cam. Mine is a tad bigger than the GM847 and the lsa is set around 107 cant' give the exact specs in respecsts to both Lloyd and Bret.
