le2 track times
Old Oct 14, 2006 | 04:57 PM
Taubr Unit's Avatar
Default le2 track times
i wanted to go with the le3 package but people say its bad for a stock bottom end. However i do not DD my car. So im looking into the le2 package. What times are you guys turning with a le2 and stock bottom end?
Old Oct 14, 2006 | 05:27 PM
1SLO6's Avatar
i am running a big head and cam package on my car with a stock bottom end. I have no problems but just have to be careful my car revs hard past 7000 rpm which is no no zone on stock rod bearings. I am not sure about the lift numbers on a GM347 but u should be fine as long as you keep the power under control.
Old Oct 14, 2006 | 05:48 PM
nhra_crazy's Avatar
I helped install an Le2 package on my friends 95 ta with 50k on it. With bolt on's and 4:11's he went 11.80 in the 1/4 2 weeks ago through an m6. Very impressive package I will be ordering my setup in the next 2 weeks!!
Old Oct 14, 2006 | 07:56 PM
Chevydomination's Avatar
I got the LE3 heads and cam package, it's going in a forged 355 with juice. Hoping for mid 10's on spray. LE heads and cam packages are awsome for the price tag.
Old Oct 14, 2006 | 09:30 PM
luda0840's Avatar
Has Unresolved Sales
le3 here and i ran a 11.6 in 3500 elevation
Old Oct 15, 2006 | 12:06 AM
Taubr Unit's Avatar
but i seen some posts about not running the le3 on stock bottom ends. I dont see why but for the extra couple hundred bucks id rather by that package. I also got a 3200 stall, built trans and 3.73's. Just askin for heads and cam.
Old Oct 15, 2006 | 06:27 AM
z_speedfreak's Avatar
well how about the LE3 w/ an LE2 cam, then you wouldnt have to spin it so high
Old Oct 15, 2006 | 09:58 AM
toby's Avatar
i have the le2 heads on a stock bottom end. car ran 11.8 last week with a big custom cam. lloyd said the valves in the le3 heads are too big for the stock pistons. i would say get the le2 heads and a le3 cam. brian
Old Oct 15, 2006 | 11:48 AM
Taubr Unit's Avatar
humm, yea good call. Cause he said its like a 847 cam and i know ppl run that 847 cam on stock bottom ends. So good call. Does anyone know a price on the "super le2" package? I emaild him a few times and he never got back to me.
Old Oct 15, 2006 | 12:29 PM
flame's Avatar
http://www.eportworks.com/LT1LE2.htm
Old Oct 15, 2006 | 03:11 PM
Taubr Unit's Avatar
now how are these packages for upper rpm power. I got WAY more then enough low end power but i need upper rpm power bad! I deff. dont mind loosing some low end to gain high end. So how are these le2/le3 for upper rpm power? Anyone got a dyno graph to show?
Old Oct 15, 2006 | 04:04 PM
ggk's Avatar
ggk
maybe i am going crazy i cant find anything about lloyd elliot. i hear good things about the le2 and le3 packages but i cant find any info on purchasing them. is there a reason for me not finding a place to buy them.
Old Oct 15, 2006 | 04:29 PM
flame's Avatar
Can you not see the post I made 2 above yours?
Old Oct 15, 2006 | 04:43 PM
ggk's Avatar
ggk
i left the rely to thread window on from like 9 o clock this mourning.
i just got to postin sorry about that.
thanks for the link flame
Old Oct 15, 2006 | 04:57 PM
Taubr Unit's Avatar
how about the le1 package? For $1200 for cam and heads, dont sound too shabby eaither.
Old Oct 15, 2006 | 05:27 PM
flame's Avatar
The LE2 uses better springs so its worth the extra especially if you wanna run a fairly large cam.
Old Oct 15, 2006 | 10:03 PM
firehawk408's Avatar
Lloyd told me that the stock piston do not have the valve reliefs to clear the larger valves that are installed on the LE3 heads. Therefore making them a no no on a stock bottom end. Otherwise if the bottom end is rebuilt with piston containing valve reliefs I would assume you would be fine.
Old Oct 15, 2006 | 10:14 PM
Taubr Unit's Avatar
ok, makes more sence now. Looks like ill do the le2 heads with the le3 cam. Now dumb question, but you figure $250 for a cam, making the heads $1500. Now would it be better/more power if i bought like a 847 cam and some trick flow heads or something? $1500 for stock casting heads seems a bit steep to me.
Old Oct 16, 2006 | 07:18 PM
flame's Avatar
The custom cams Lloyd sells are a billet core so they cost a bit more. The Trickflow heads would need to be milled down alot due to the large combustion chambers they come with. Talk with Lloyd if you have any questions.
Old Oct 16, 2006 | 11:57 PM
Taubr Unit's Avatar
ok, now thoes packages are with new heads right? I dont send mine to him and he builds mine up. So i could still sell my heads for a couple bucks, making the package yet a little cheaper. If i need to send in mine, thats even more expensive for my heads built up ya know.
