code 36 high resulotion
Old Oct 16, 2006 | 09:12 AM
mike2244's Avatar
Default code 36 high resulotion
my car is running like **** and i get code 36 high resulotion. i changed the opti and still the same problem. i also changed the icm and still the same problem. could i have got a bad opti or is it something else any help would be great.
Old Oct 16, 2006 | 11:38 AM
vigalante LT1's Avatar
I think a code 36 is a bad mass air sensor. I do not have a book near but that would definitley make the car run bad.
Old Oct 16, 2006 | 12:43 PM
mike2244's Avatar
the code is high resolution fault it is a 94 car.
Old Oct 16, 2006 | 12:48 PM
infinitebird's Avatar
If you replaced the opti and it's still there it could be a short in the connector or a bad ground or something.
Old Oct 16, 2006 | 12:57 PM
juicedimpss's Avatar
could also be an issue with the pins on the 4 pin connector in the opti. make sure they are clean,and tight.they get wallowed out with unplugging the opti.
Old Oct 16, 2006 | 10:48 PM
mike2244's Avatar
found the problem it was a bad pin connection that connects to the opti. she runs great now
