Fuel Pump install ???
Thanks
When the pump is half out you have to turn it to get it out.
As in pull the top of the pump towards you so that the bottom of the pump assembly is moving away from you. Or is it the other way around.
It does NOT come straight out up and down.
. Merv, do you have any pics of the plate you made? How do you attach your plate? If I cut a hole out I want it to look neat when I'm finished.
I also used some self adhesive foam weather strip around the border of the cover plate. The weather strip was about 1/2" thick un-compressed. With sheet metal screws holding the plate down its no more than 1/16" thick. So it seals good, and doesnt create a noticeable bulge under the carpet.
The pics are on my Computer which isn't hooked up right now..
