Fuel line adapter
http://cgi.ebay.com/ebaymotors/LS1-L...42341380QQrdZ1
Earl's Aluminum Tube Adapters
They're designed to mount directly onto a steel or aluminum hard line. The little gold ball jams up inside of the hard line and flares it from the inside as the fitting is tightened.
Here's a link to the only place that I was able to find them online:
http://www.mpsracing.com/products/ea...5Fadapters.asp
You'll need both a 3/8" and a 5/16" -6 AN male adapter for attaching fuel line to the hard lines underneath the car. Hope that helps.
The end on the metal line in these cars is called a compression bead, it's the same ends that are on the crossover line going from one fuel rail to the other and the same kind of end going into the FPR. When I put the blower on my car a few months back I used the stock rails and had to make a crossover line so I made a lil tool to make that compression bead, I never could find any fuel line already beaded like that.
Basically the only option is to cut the metal line and flare it for an AN fitting or use a compression fitting like in the pic above, but I don't trust them. By the way, they sell them on summit too. If I wanted to save the factory metal lines in case I wanted to go back stock I could use my lil bead tool and make new metal lines but that seems like a waste of time.
http://www.performanceplumbing.com/FuelLineKits.html
Never used them but there is a recent thread about the "LT1 fuel line mod" and i posted a link in there that shows a guy who converted to an lines and moved the stock ones so they dont come out of the drivers side fender. Take a look.
Mike
I ahve know about Performance choice and if I am not mistaken Gary over there told me it was about $100-$125 for the kit with the 4 fittings and the -6 braided line.
I found this on ebay today
http://store.summitracing.com/partde...5&autoview=sku
I am pretty sure this will work, but I am not for sure on what is needed on the other end that connects to the fuel hard line.
However I was looking through summit last night in the magazine and I seen where the LT1 specific Fuel rail -6 an fitting was $14.95 So I may just give them a call about that.
Summit sells the stainless Braided a little cheaper than Russel and Earl's and it looks just as good. I need to get proabably 25Ft of -6an (about $70.00 if I remember) b/c I am doing the steam lines with 90 1/2 fittings and -6 line.
