lt4 intakes = WOW!
Originally Posted by Meen95z
Someone mentioned heads, intake and cam in Summit for $1200? I like to see where you found that at.. Maybe for the heads alone..
http://web.camaross.com/forums/showthread.php?t=480010
HERES THE ONE FOR 675
http://cgi.ebay.com/ebaymotors/GENUI...spagenameZWDVW
THIS IS THE ONE FOR 255
Originally Posted by Taubr Unit
so will this intake fit the lt1 heads? Then if it does, i see a hole to run a reg. dist correct? Then ill need to buy a cam with a dist. gear on it right?
#32
thats cool. But im looking for a carb manifold so i can run a reg. dist. and a carb. Thats a single plane but still for EFI. A lt1 motor with a reg. dist. and a carb in MY OWN build up would be mint. Like a vic. jr. for a lt1 motor.
http://store.summitracing.com/partde...0&autoview=sku
#33
I dont know if this was mentioned but summit sells the carb intake for the LT1 For motors 1992 and up NAL-24502592 is the part# I did see the the one for LT4 is my last issue but dont see it now.
