Engine stuff..
Old Oct 20, 2006 | 12:59 PM
the_merv's Avatar
Veteran: Air Force
Default Engine stuff..
I am seeing how this will affect my Engine. I know it will be a gain, I am wonderin what your guy's inputs are.
I bought Forged Pistons and Forged Rods for the new Motor I am putting together. I had to get the whole Rotating Assembly balanced due to some differences in weight. They Balanced the Crank, Pistons(with Rings), Rods, and Flexplate. I had to spend $200 dollars that I wasn't planning on basically. It's just a 350, so what will I expect. I know that it will be running smoother..
Old Oct 20, 2006 | 02:30 PM
LT1MAN's Avatar
you can expect for it to be harder to break a rod or piston, you can spray the hell out of it.
Old Oct 20, 2006 | 03:41 PM
the_merv's Avatar
Veteran: Air Force
I am trying to figure out how the Engine will perform basically, as far as response and RPM movement. Some people said it will be slower, but I see it about the same, if not faster seeing how it will be balanced.
Old Oct 20, 2006 | 03:44 PM
01WS6er's Avatar
Your new rotationg assy is probably heavier than the stock assy. I see too that it will be harder to break. You might get a few more RPMs out of it since it is balanced and forged. If you are asking about more HP or Torque, I don't see any unless U went to domed pistons or strocker.
Old Oct 20, 2006 | 03:47 PM
the_merv's Avatar
Veteran: Air Force
I was meaning as far as response..
Old Oct 20, 2006 | 04:19 PM
Formula350's Avatar
That thing will rev up and down like you wouldn't believe. You'll love it. My friend had a 70 Dart Swinger 340 that was fully balanced. It was awesome! I'd love to have a balanced motor myself :\
Old Oct 20, 2006 | 04:32 PM
the_merv's Avatar
Veteran: Air Force
Guess I got a good gain then.. I didn't really feel like spending the $200 on top of that. I have been dropping money quick on that new motor.
Old Oct 20, 2006 | 07:11 PM
Bad Dad's Avatar
SMOOOTH my set up ...the higher you rev the smoother it is.
Old Oct 20, 2006 | 08:50 PM
the_merv's Avatar
Veteran: Air Force
Cool. I shift at 6100, so I guess it will get to it a little quicker and easier..
Old Oct 20, 2006 | 09:02 PM
Formula350's Avatar
Oh you'll go higher than 6100. You might even get 7K if you don't float the valves or run out of the upper ends powerband LOL
Old Oct 20, 2006 | 09:06 PM
the_merv's Avatar
Veteran: Air Force
The Cam stops building at 6100 area, so we shift it there. With the Heads ported a little, it might go a bit higher, but I am leaving it there.
Old Oct 20, 2006 | 09:23 PM
LT1BRN's Avatar
I shift at 6500 bro, Hotcam with 4L60E gets the best results at that, and I'm not talking out of my ***, a Guru told me that, and that where my car will shift.
Old Oct 20, 2006 | 09:33 PM
the_merv's Avatar
Veteran: Air Force
I am keepin it at 6100, it will shift back down into the Torque band, then come back up.
Old Oct 20, 2006 | 09:38 PM
LT1BRN's Avatar
what ever you do, wish you the best, I guess both of us are in the same leage messing around with hot cam, stock cubes and port matched heads.
Old Oct 20, 2006 | 10:01 PM
the_merv's Avatar
Veteran: Air Force
Yea, looks like it..I should get a thread going of all of us..
Old Oct 20, 2006 | 10:19 PM
MrCadillac's Avatar
If it stops building power and droping off at 6100, don't you wanna shift at atleast 6300-6400? See, if you shift right at the peak, it drops it to right below the peak torque, which isn't the best idea. I forget where I was reading this, but you do wanna shift a bit above the hp peak.
But don't take my work for it, I urge you to shift it at 6100, then shift it at 6400 into 2nd, and about 6300 into 3rd and see which run gives you the best ET.
Old Oct 20, 2006 | 10:23 PM
LT1BRN's Avatar
exactly what i understand.
Old Oct 20, 2006 | 10:34 PM
the_merv's Avatar
Veteran: Air Force
I want to get it back into the torque as much as possible. That tops at around 3800, and slowly drops.
By Brett Foote | 2026-06-04 05:00:17
