75 Shot on stock motor
Old Oct 22, 2006 | 01:31 AM
626KLZE's Avatar
Default 75 Shot on stock motor
I was wondering how a 75 shot would do on my stock LT1? I just need it for 1 race. But I always been kinda scared to spray my car.
Thanks
Old Oct 22, 2006 | 01:49 AM
buffman's Avatar
as long as it isnt running lean, and everything is in proper working order, I dont thinka 75 shot is going to hurt your car...
Old Oct 22, 2006 | 01:55 AM
skatinjay27's Avatar
spray 100 wet on stock motor(internals) and it works great and have yet to see any NA performance loss. just install it with all the proper saftey features. but as a warning one you spray youll be adicted
Old Oct 22, 2006 | 05:20 AM
Dragframe's Avatar
people spray 150 shots without problems on stock motors (some spray even more)
Old Oct 22, 2006 | 10:31 AM
626KLZE's Avatar
OK Thanks, I got to get revenge on this mustang for spraying me last night
Old Oct 22, 2006 | 10:38 AM
TWS's Avatar
TWS
Bottom line I think a 75 shot should be OK as long as every thing else is in proper working order. (ie, fuel and ignition). I would advocate installing at least a window switch, and if you want to be very carefull, a fuel pressure safety switch.
Check how much timing you are running via LT1 Edit or Tuner Cat etc. You may need to retard it a couple degrees to avoid problems on the spray.
I do not recall what the stock ring end gap is on LT1's but you don't want to generate too much heat and have your ring ends butt. That means good bye to at least that piston.
Are you looking to go wet or dry?
Old Oct 22, 2006 | 02:26 PM
626KLZE's Avatar
Im thinking dry, but i hear wet is the better way to go.
Old Oct 22, 2006 | 04:01 PM
Dragframe's Avatar
spray more than a 75 shot....
Old Oct 22, 2006 | 08:30 PM
LT1BRN's Avatar
75 shot is for imports, J/K.
a friend of mine sprayed a 200 shot on his bone stock 96 SS for a whole season, nothing happened to the car and it still runs smooth, just get the least of safety gadgets as was said before and you will be fine.
warning, spraying is like crack.
Old Oct 23, 2006 | 09:50 AM
626KLZE's Avatar
All I need is about a 75 shot to beat him, all he got is a 99 Mustang GT with Exhaust/no headers, 3.73 gears. But yet i know he sprayed me because he got me by about 3 cars, with those mods he still couldnt beat me without spray, even though im stock.
Old Oct 23, 2006 | 05:02 PM
Daez's Avatar
Go 150 shot, and beat him by 5 cars >.<
Old Oct 23, 2006 | 05:35 PM
ThisLT1's Avatar
There was a guy out last night, auto lt1 with bolt ons and 180 dry shot. Says hes had no problems with it at 120k mi.
Old Oct 27, 2006 | 04:02 PM
626KLZE's Avatar
lol! I think he was spraying close to 150, It didn't impress me. But then again it's just a Mustang GT i guess he needs the extra boost.
Mustang GT's
Old Oct 27, 2006 | 04:44 PM
speed_demon24's Avatar
Mustang GT's
A bolton GT won't need spray to beat a stock LT1.
Old Oct 27, 2006 | 09:21 PM
Daez's Avatar
Full bolt ons most likely, GT's don't seem to gain much from just bolt ons like our cars do(or at least my friends cars haven't). Some stock LT1's do 14.0 1/4's. most 04ish Gt's I've seen with bolt ons run in the 14.4 range(this is without headers though)
Old Oct 27, 2006 | 10:20 PM
I was in my friends bolton GT when he put a couple cars on a 97 Z28 with a catback.
Old Oct 28, 2006 | 01:00 AM
Rowdy94's Avatar
My LT1 went 14.0 to my buddy's 03 GT' 14.3 with a catback and intake
Old Oct 28, 2006 | 01:01 AM
96mikez28's Avatar
I've seen a '95 z28 blow off the intake manifold from a 150 shot. bit of advice, don't start sprayin till about 3k RPM's or the nitrous will travel back up into the intake on a dry shot
