TONS of SES codes help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!
MALF 78: Fan 2 Fault ,
MALF 16: Lo-Res Fail ,
MALF 67: A/C Press Sensor Degraded ,
MALF 84: 3-2 Downshift Feedback Fault ,
MALF 97: 4000 PPM VSS Circuit Fault ,
MALF 55: Fuel System Lean ,
MALF 24: Output Speed Low ,
MALF 29: EAS Electrical Fault ,
MALF 64: Right O2 Lean ,
MALF 37: Brake Switch Stuck On ,
MALF 52: Oil Temp Low ,
MALF 41: EST Open ,
MALF 27: EGR Electrical Fault ,
MALF 13: Left O2 Fail ,
MALF 82: Shift A Solonoid Fault ,
MALF 95: Oil Life Lamp Circuit Fault ,
MALF 63: Right O2 Fail ,
MALF 80: Transmission Component Slipping ,
MALF 22: TPS Low ,
MALF 50: System Voltage Low ,
MALF 25: MAT High ,
MALF 71: A/C Evap Sensor Failed ,
MALF 12: No DRP Pulses ,
MALF 81: Shift B Solonoid Fault ,
MALF 53: System Voltage High ,
MALF 22: TPS Low ,
im guessing this is something electrical, any clue?
I think you might have a major short, or loss or power somewhere after your battery/alternator.
It might be triggering a shitload of sensors, or throwing them off.
Does the car run?
When did it start doing this?
Maybe a rodent got in there deep and chewed some wires?
Does the car run?
