criticize my setup!!!! plz!
stock block bored .030" over
eagle forged steel crank
clevite 77 bearing
arp main studs on a 4 bolt main
eagle forged h-rods w/ arp rod bolts
JE -5cc forged aluminum pistons for an est. c.r. of 11.8
fel-pro head gaskets
stock p&p heads most likely le2 or similar with custom grind to match
stock intake p&p
as&m 54mm tb
k&n cai
1.6 comp cams gold rr N.S.A.
comp cams hardened push rods w/guideplates
spec aluminum flywheel 12.5lb?
stock water pump
no a/c
aluminum radiator possibly be-cool
as&m 1 3/4" lt headers
true dual setup with x-pipe into dual borla xr-1
Forged rods- what length?? (all dependant on the crank)
I like BBK TB's I used the 58mm, it wont hurt and its recommended by Lloyd and Bret.
Rockers- If you get a LE setup, they will recommend Pro mag NSA rockers with Promag 7/16" studs.
Flywheel- You will lose low end power with the lighter flywheel, I would recommend steel.
Waterpump- CSR works mint and is cheap, worth 10hp.
Radiator- Stock replacement works mint. Spend money on other mods.
AS&M headers suck ***. We put them on a 93, I hate them, go Longtube such as Jet-hot.
Is this going to be a N/A motor only, maybe some n2o?? I had the same situation 3 years ago, I went 383 and loved it. I spent more time dealing with cams vs emissions. Which I cannot bribe anyone. I gotta pass it.
I have owned a BBK TB, they dont whistle, CAI's whistle.
EWP is one of the best mods, Save that money from the radiator. Your motor needs to run in operating temp to make proper power. LT1's with reverse cooling can more then support 40+ degrees of timing with pump gas. I did it with 11.25 to 1, with a EWP, stock replacement radiator.
As for AS&M they were the mid lengths with 1-3/4 primaries, the bolt access, sparkplug access suck ***. Then plug wire routing is horrible. Just avoid.
and i wanna be able to get another rebuild out of it so i can have a FI prepped 383..... i just want a strong n/a that i can drive fri-sun with maybe 5-6 trips to the track a year.... now that you brought that up tho about the as&m headers i see your point about the acces to everything, i had that problem with my bbk shorties, my #6 plug was a pia... what do you think about kooks headers? i'm also not sure if i can run that high of a compression on 91.... i will be doing 4 bolt mains with arp studs... how would the 6" rod help, and would i need even more maching?
LE stuff works, Bret makes awesome LT1 cams, I had a opportunity to hang with him and he knows his ****. Cam and heads will dicatate any motor as far as cubes are concenred. If he goes 383, it'll be a bigger cam and heads and will go faster.
If your planning on a eventual 383 route, save for the eventual thing, not the here and now. Just my own opinion.
the stroke has no effect on being able to get another rebuild out of the motor. the bore size does.
how far down the road is the FI build up going to be? there are a few ways you could go about it.
build the bottom end for FI now.
select a piston that will give you the desired CR (for FI) with a large chamber head. then use a stock casting head for the mean time (if the CR is decent)
you could put the FI camm in now or later.
when its time to go FI you just need to swap to the other heads and put on the turbo/supercharger.
thats the basics of it. there will be more details of course
