Progress
It's running, just not all the way yet. I have to Shim the Starter a little bit more, and put the front Suspension back together. The Lifters has to get oil in them, cause they are not pushing up. A couple of Cylinders fired, we quit messing with it cause of the Starter, didn't want to kill it. So tomorrow looks good to have it running. It's getting there..
If your having issues gettin the rockers to pump up, remove the plugs (to relieve unnecessary stress on the rotating assembly), loosen a pair or rockers, turn the motor over untill you get oil squirting out the pushrod tip/rocker hole, then adjust the rockers using the cylinder to cylinder method. Make sure you looses the pair for each cylinder and get oil before adjusting the valves. Then install the plugs and fire her up!
If you need any clarification on the cylinder to cylinder valve adjustment, pm me.
