280XFI cam anybody
One of Bret Bauer's posts about the XFI profiles:
"Mike, How high you want to spin this thing???? There are some issues with the XFI lobes and RPM because you can't get enough spring in there to control them over the nose.
Bret"
BTW, I have the beehive springs and since its in a 383 I doubt I'll have rpm/valve float issues.
EDIT: I found the 915 springs on summit, but they have even less seat pressure than the 918s. Just something to think about.
I dont know how high you guys are planning to turn your motors, but Im not planning on going any higher than 2600ish rpm.
Theyve got to have enough pressure for me, as the engine builder built this beast for a planned 15psi of boost.
I'm using the Patriot Gold dual springs for LT1 kit with the TI retainers and 10 degree locks. I have Manley valves, with .250 tip, so I needed to use -.050 locks. This brought my seat pressure up a bit, more than I really liked, but had the heads on the cat by the time I noticed the clearance issure with the SA rockers that required the -.050 locks. Installed height is reduced with these locks, so I am at 170 seat and 320+ open. We will see how this works out.
Have not tuned, don't know power or if will need 30 pound injectors yet.
Have not gone WOT yet (no tuning) so don't know how it'll do there yet.
Will post later on this. PM me to remind me.
available depending on needs on the dyno.
ALos have a racetronics pump sitting around looking for a purpose as needed.The Best V8 Stories One Small Block at Time
Car has only been idled for a few minutes thus far, not driven at all. It's at the shop awaiting dyno tune; have 30s, 42s, and 87s
ALos have a racetronics pump sitting around looking for a purpose as needed. That's the purpose of WBO2; I'll get to see duty cycle and A/F ratio as we raise the revs, and see where the injectors and/or stock fuel pump starts to become a problem long before engine damage can occur. At which point we stop, switch fuel components as needed, and then go on....
Help to have friends with a dyno...
http://www.camaroz28.com/calcs/index.shtml
