96 WS6 Misfire Problem Almost Solved...
Old Oct 25, 2006 | 05:46 PM
buk's Avatar
buk
Default 96 WS6 Misfire Problem Almost Solved...
If any of you remember I had a misfire problem with my 96 WS6. After replacing almost all of the ignition components I finally had a chance to get it on a snap-on scanner to read the misfire counts. Turns out cylinder 4 was the culprit, and after checking compression/spark on it I determined it was most likely the fuel injector. Seeing as how I have intentions of modding the car further I picked up and installed a set of SVO 30lbers.
Now the problem: Although this fixed 98% of the problem, there is still a SLIGHT hesitation at low throttle. ie: 2100-2900rpms. All other instances the misfire is fixed. Could this be caused by the fact I did not switch over the tune for the bigger injectors yet?
If anyone has any thoughts on this nagging problem please let me know, I appreciate any and all input.
*EDIT*
Just thinkin out loud here, could this possibly be due the the crack I found on the TPS sensor flange?
Old Oct 25, 2006 | 06:09 PM
FAD2BLK93's Avatar
The bigger injectors would send more fuel, the computer would send a pulse for the stk injector size but would actually be putting more fuel in, I believe it would be running richer than it should, and I dont believe that would cause a bog, being lean would cause a bog. just my .02 correct me if I'm wrong.
