Comp Cam question
Old Oct 29, 2006 | 07:10 PM
goodrich969's Avatar
Default cam question. Cmon in!
i got a 224/230 .510/.515 11 and it came with these springs http://store.summitracing.com/partd...15&autoview=sku
and seats/retainers
Im going to be buyin 1.6 rr's and new rods and gaskets. What else should i get with it.
Also, should i get a 218/224 .495/.502 112 cam instead.. it seems pretty mild... kind of similar to the LT4 hot cam isnt it?
Old Oct 29, 2006 | 08:21 PM
seawolf06's Avatar
That link didn't work. I'd say you should also replace the timing chain. Do a search about your options with that. I'd stick with the 224/230. After a while you'll want to go bigger, so the other one would be way to small, but that's just me, plus, you already have that cam.
Old Oct 29, 2006 | 08:29 PM
Ls1Bait's Avatar
I would stick with the first cam. It will give you some nice power and keep it very nice and streetable.
Old Oct 29, 2006 | 08:41 PM
tahst what i was thinking... so what else do i need for it... rr's/new gaskets/ RODS??
Thanks alot
Old Oct 29, 2006 | 08:43 PM
seawolf06's Avatar
Comp cams pro mag 1.6 RR, NSA 7/16 stud
ARP 7/16 studs
felpro gaskets
Comp cams hardened pushrods
GMPP guideplates
Old Oct 29, 2006 | 08:45 PM
http://store.summitracing.com/partde...5&autoview=sku
thats the springs...
whats the difference of NSA and APR studs?
Thanks again
Old Oct 29, 2006 | 08:47 PM
seawolf06's Avatar
Thanks again
Search google or here: www.camaroz28.com
Old Oct 29, 2006 | 08:50 PM
seawolf i looked and those guidplates are 2.76$ how many will i need?
seawolf06's Avatar
8, get them from Thunder Racing.
Old Oct 29, 2006 | 08:52 PM
also in your opinion where should i get those studs from and which ones would you recommend. Thanks alot
Old Oct 29, 2006 | 08:53 PM
seawolf06's Avatar
Shop around for the studs and just get whatever's easiest. Probably summit if you can afford it. ARP 7/16 studs for LT1 heads.
http://www.thunderracing.com/catalog...&sid=475#P1227
are those the guidplates that i should get.
Old Oct 29, 2006 | 08:55 PM
http://www.thunderracing.com/catalog...&sid=323#P1229
also those are the studs that im probably going to get... i need how many of these? Thanks
Old Oct 30, 2006 | 11:48 AM
anybody else wanna offer some insight. Thanks alot
Old Oct 30, 2006 | 11:51 AM
seawolf06's Avatar
Yes on the guideplates and the studs. If you can find the Comp cams hardened studs cheaper, they are ARP also. Just make sure you match the studs to the RR that you get. 7/16 is recommended.
Old Oct 30, 2006 | 12:47 PM
how do i know if they match?
Old Oct 30, 2006 | 12:56 PM
seawolf06's Avatar
Just buy 7/16" rockers for 7/16" studs.
Old Oct 30, 2006 | 01:00 PM
okay so when im lookin for rr's im going to get 1.6's but make sure they're 7/16's
Old Oct 30, 2006 | 01:05 PM
seawolf06's Avatar
And get 7/16 studs to match.
Old Oct 30, 2006 | 05:05 PM
seawolf06's Avatar
do i really need new studs? i mean i might as well but do i really?
For less than $40, why not? You could also reuse your stock pushrods, but for so cheap you really should upgrade to hardened ones. Do it once, do it right.
