Ready to pull the engine out the bottom...Got a few questions.
1. I bought a ATV jack to go under the K-member and I will use a floor jack under the tranny. The car is at just the maximum height for the ATV jack so I am going to use both jacks to lower the K-memeber and the tranny. Is this the way you guys are doing it?
2. After I have done step #1 and if I need to raise the entire car up higher to slide the K-member with engine out from under , can I place a jack under the metal support under the radiator, is that cross member strong enough to support the weight of the car?
3. Does the sway bar need to come out?
Thanks all.
