Cam and parts question
Old Oct 31, 2006 | 03:48 PM
goodrich969's Avatar
Default Cam and parts question
So far i have a custom cam
@summit part number CRN-10308-1 those springs and seats. I believe theyre crane doubles. I think thats what i was told
and retainers
I believe im going to get gaskets.. From felpro, do I need head gaskets or intake gaskets?
Im gettin GMPP guideplates with 7/16 crane cams screw in studs
And Im gettin some probably GMPP chromoly pushrods but im not sure what size to get. Some insight there would help. Thanks alot!!
Old Oct 31, 2006 | 05:33 PM
Matts94Z28's Avatar
7.200" pr's
Old Oct 31, 2006 | 06:27 PM
JimboManJones's Avatar
Make sure they are 5/16 diameter too
Old Oct 31, 2006 | 06:48 PM
seawolf06's Avatar
If you search summit you'll get all the right part numbers you need, or get them from Thunder like I told ya. You need intake gaskets, not head gaskets. You'll also need a timing cover gasket set. With both of those you should have all the gaskets you need.
Old Oct 31, 2006 | 06:50 PM
maybe2fast's Avatar
I believe the lt4 has 7/16 rocker studs and the LT1 has 3/8
Old Oct 31, 2006 | 08:23 PM
so should i look for 7/16 or 3/8 studs?
Old Nov 1, 2006 | 08:34 AM
7/16 or 3/6 because ive been told to get both of them.. So im not sure which one.
Old Nov 1, 2006 | 09:44 AM
zlightning's Avatar
That would depend on your rockers. If you get rockers that require a 3/16 stud then you need to get a 3/16 stud. Same for the 7/16 stud.
Old Nov 1, 2006 | 12:21 PM
im gettin 1.6 rr's probably, either LT4 rockers or pro mags or cranes.
Old Nov 1, 2006 | 04:36 PM
maybe2fast's Avatar
is the thread in the head the same in the LT4 and LT1s?
Old Nov 1, 2006 | 04:56 PM
are you asking me? because i dont know what your talking about
Old Nov 2, 2006 | 08:48 AM
maybe2fast's Avatar
it is just a general question to get some answers to help all that want to upgrade their LT1s
Old Nov 2, 2006 | 10:18 AM
all screw in studs(like lt1/lt4s) have 7/16 threads that go into the head, the top portion(where the rocker nut goes on) is either 3/8 or 7/16, if you get new rockers and want new studs, get 7/16s studs and rockers(they are stronger/more stable at higher rpms then 3/8s)
Old Nov 2, 2006 | 05:34 PM
So for for with 1.6 rr's the pushrods should be 7.200" and 5/16? For sure?!
Old Nov 3, 2006 | 10:20 AM
Yes. 7.200 and 5/16 for sure,
Old Nov 3, 2006 | 11:01 AM
Awesome, my cam has one or two little small grooves in it.. Ill post some pictures but I was wondering if it was still perfectly functional. Thanks so far.
Old Nov 3, 2006 | 02:56 PM
do you think its safe with one or 2 tiny grooves... my shop manager called them lil grooves... Still safe??
Old Nov 3, 2006 | 04:07 PM
Someone please answer my above question, I have another question. What retainers should I get? Thanks
Old Nov 3, 2006 | 04:35 PM
Another question to go with the above 2....i want to get new bearings incase mine are worn... what size and everything would i be looking for. Thanks again
Old Nov 4, 2006 | 09:00 AM
anyone?
