Not LT1 but Miniram II Video
Here is the Video of the tach only.
http://video.ls1tech.com/video/e94b6...6c0010267d.htm
Assuming this information
---My Vette has 3.73 gears,
---700r4 trans with a full manual valve body
---Starting off in 2nd gear 0-80+mph in 2nd alone
---315/35/17 drag radials.
---Light launch, rolling into the throttle to start.
---I let off the gas at 6050 rpm in 3rd.
---In the Video you can see it briefly flash to 1500 rpm which is where I released the brake. ~2 seconds into the movie.
---I can't wait to see what it does at the track with the use of 1st gear.
I have derived the Following information,
0 to
MPH if the Tire Diameter is
115.8 24
118.3 24.5
120.7 25
123.0 25.5
The factory rates these tires at 25.7 (bs) and i have about 32 psi in them.
Last time I measured them they seem to measure out to be about 24" with about 20 psi. I dont know how much they grow at 115 mph.
Anyway you look at 0-115 in about 10.3 seconds isnt too bad considering its a street start in an extremely tall gear 1.62*3.73 and I didn't stomp the throttle to start.
p.s. Does anyone know whats up with my 2-3 shift? It hangs for a moment inbetween gears.
Also do I have a legitimate shot st high 10's with installing the Accel gen 7 and proper tuning and a killer Launch?
0 to
115.8 24
118.3 24.5
120.7 25
123.0 25.5
