Kooks headers?
Old Jan 2, 2007 | 07:19 PM
hyperzone's Avatar
How are they clearance wise for specifically plugs & wires compared to pacesetters?
Old Jan 3, 2007 | 12:38 AM
SS MPSTR's Avatar
I just put them on my C6 and was very impressed with the fit and quality.
Old May 26, 2007 | 03:58 PM
SiDeWaYZz28's Avatar
are they a slip fit style collecter or 3 bolt style like hookers?
Old May 26, 2007 | 06:25 PM
InsaneAuto86's Avatar
Amazing headers! Easy install and top quality!
Old May 26, 2007 | 08:44 PM
ABA383's Avatar
Mine are slip fit...I have the Kooks stepped 1 3/4 - 1 7/8"...Very nice headers with great ground clearance, plug access...I have since changed from slip fit to Dynatech stainless V-band clamps to go with my true duals...
--Alan
Old May 26, 2007 | 09:07 PM
always faster's Avatar
They are the best has far of everything:
-The sound is amazing
-The fittement is perfect(only the steering shaft bolts need to be grind a little)
-The quality of the finish and weld are breathless
-They will last without rusting
By the way since where in the subject im using the short oil filter but it still would not pass between the oil pan and the headers.When i change my oil yesterday(breaking oil change)i was obligated to use a "prybar" to be able to let the filter pass?
Is it normal?
Old May 27, 2007 | 06:29 AM
ABA383's Avatar
Which filter are you using? I use the AC PF454 and it clears everything fine...I can get my whole hand around it...
--Alan
Old May 27, 2007 | 10:57 AM
--Alan
I use the same.I can get my hand around it but the filter doesnt pass between the stock oil pan and the headers once its unscrew...
Old May 27, 2007 | 12:14 PM
im runing the canton pan and spohn k memeber you think I will run into any fitment issues?
Old May 27, 2007 | 02:33 PM
SRZ's Avatar
SRZ
--Alan
Do they build them w/ the build them w/ v-band style now? I have FLP's and like them for being able to swap ORP to Cats. But their 1 3/4 - 1 7/8 w/ a 4" outlet is oh so tempting.
Old May 27, 2007 | 05:40 PM
ABA383's Avatar
I don't think they do...Mine were modded after install, but I bet if you called them, they'd weld on the collars for the band clamps...
--Alan
Old May 27, 2007 | 10:58 PM
  #32
LT1Z's Avatar
Originally Posted by JUICED96Z
Best sound, fit, quality, pretty much all the single didget guys use them, well most.
More would use them if it was not for the cost, oh and they are stainless so they will not rust.
How would they sound different than a Hooker or PS LT if they have the same primary size? just curious
Old May 29, 2007 | 10:37 AM
  #33
Vicious95Z28's Avatar
luv mine
Old May 30, 2007 | 12:05 AM
  #34
Dragframe's Avatar
pipe shape and length... a lot comes into play with the sound of an exhaust... think how a muffler works.
