Kooks headers?
Old Nov 2, 2006 | 05:45 PM
Funkybird's Avatar
Default Kooks headers?
Do any of you guys have Kooks headers? I'm thinking of swapping out my Pacesetter LT's for some Kooks LT's, I need to know what you guys think of them and I would also like to see some pics cuz I don't know if they would clear my Procharger.
Old Nov 2, 2006 | 06:24 PM
Quick96ss's Avatar
I do they are amazing. The best headers i have ever seen dont question it. The best headers money can buy.....
Old Nov 3, 2006 | 02:27 AM
JUICED96Z
Guest
Posts: n/a
What he said.
Old Nov 3, 2006 | 02:54 AM
Ironxcross's Avatar
ive heard only good things about them...
Old Nov 3, 2006 | 12:14 PM
slick1851's Avatar
Ive yet to so any dyno numbers at all with them!
Does anyone have a dyno sheet on a near stock LT1?
Old Nov 3, 2006 | 04:40 PM
Funkybird's Avatar
Do you have any pics of them? I need to see what the driver side header looks like.
Old Nov 3, 2006 | 05:02 PM
OrangeLt1's Avatar
Not a near stock dyno but it does have the Kooks 1 3/4" X 3" LT's on it. Great headers though. Dyno below the sig.
Matt
Old Nov 3, 2006 | 05:31 PM
Quick96ss's Avatar
i put down 434 rwhp and 414 rwtq with a 383 on stock ported heads and a smaller cam....
Old Nov 3, 2006 | 06:48 PM
ABA383's Avatar
Best headers I've ever used by far for fit, finish, quality, plug access, ground clearance...I have the stepped 1 3/4 - 1 7/8" on my 1995 383 and trap just shy of 120 with a weenie cam...Worth every $$$...
--Alan
Old Nov 3, 2006 | 07:52 PM
Turbo_6's Avatar
Akan, Did you have to relocate the oil filter or any other modifications needed to make the stepped 1 7/8" headers fit? What is the price on a set? Thanks.
Old Nov 3, 2006 | 08:04 PM
ABA383's Avatar
I do not have an oil cooler, but I hear that it can be an issue...On my application there were no mods other than some slight clearancing of the bolt on the steering shaft...It had to be ground down a hair to clear a header tube...and I had to switch to an AC PF454 oil filter (which is the stock filter, and its a bit shorter than the long PF 1218 I used with shorties)...I got them during a buy in with F-Body Central in Baltimore, MD and go them at a great price...They were over $800 for the stainless stepped...dunno what they are now...
--Alan
Old Nov 4, 2006 | 09:18 AM
Vicious95Z28's Avatar
Love mine. I've never been more impressed with a set of headers. I have slightly lowered car and I never have to worry about the headers, just the mufflers.
Old Nov 4, 2006 | 08:52 PM
David94TA's Avatar
I just switched from Hookers to Kooks. I gained at least 1 inch of ground clearance over the Hookers. I had to remove the stock oil cooler, but no problems with the oil filter. I am very happy with the Kooks. For any of you thinking about going with Kooks, I have 2 of their 3" Y-pipes for sale and I can save you some money. One Y-pipe has cats and the other doesn't. FYI you can also get their Y-pipes with a 4" outlet--they don't advertise that on their website.
Funkybird, I'll try to get you some pictures. Just e-mail me at wdkdds@Comcast.net and put "Kooks pictures" in the subject line.
And to answer your question about the headers and the Procharger--no problem.
Old Nov 6, 2006 | 11:49 AM
redneck01's Avatar
friend of mine had them on his z. beautiful headers actually the best ive ever seen. i'd love to add some stepped one to my 383, but i dont know if id gain more than 5 hp for $900.
Old Nov 6, 2006 | 01:52 PM
knight17Z's Avatar
i wouldn't mind having your old pacesetters
Old Dec 31, 2006 | 04:38 PM
SiDeWaYZz28's Avatar
Do the kooks have clearence issues with CANTON oil pans?
Old Jan 1, 2007 | 08:34 AM
sheikss's Avatar
Just put some stepped on my 97 and everything on the drivers side was VERY close. I had to get rid of a few things like my low oil level sensor ( I run a canteen pan ). And the steering runs close also. Hopefully everything clears and doesn't hit. Also you'll need to run an AC PF454 oil filter it makes life a whole lot easier. The quality is amazing though.
Old Jan 1, 2007 | 10:22 AM
hyperzone's Avatar
So... you guys that like these headers so much, what major improvements do they have over say my pacesetters? Or other brands? Its understood that you like them, they look great, add power,... That sounds like a description of most headers... What sets them apart?
Old Jan 1, 2007 | 12:56 PM
JUICED96Z
Guest
Posts: n/a
Best sound, fit, quality, pretty much all the single didget guys use them, well most.
More would use them if it was not for the cost, oh and they are stainless so they will not rust.
Old Jan 2, 2007 | 05:16 PM
GeorgeR@kooks's Avatar
LS1TECH Sponsor
Yes They Will Clear A Canton
