best underdrive pullies
I had a Aeromotive, they all basically work the same.
I would look into a Electric water pump, an easy 10 hp gain, 1 tenth at least and around 1-1.5 mph increase
IMO the right way to do this would be a lightweight damper and hub say from ATI lose some rotating weight, get the UD and get a top notch damper all in one, I don't have one yet but it is saved on my Summit wish list.
Off the top of my head I want to say the stock damper is 10-12lbs without the hub ATI has one at just 4.5lbs and an aluminum hub at just 1.4lbs, their steel hub is 2.9 and I think the stocker is heavier yet. Shave 6-8lbs rotating weight at engine RPM and UD the accessories and you will have a SOTP and strip difference. Rotating weight makes a much larger difference than dead weight and the larger the diameter of the weight and higher it spins make even more difference, the damper/hub are not large in diameter but they spin FAST much faster than tires and wheels where everyone knows to try to save weight.
