355 LT1 built for boost
Old Nov 8, 2006 | 11:04 PM
96silverram's Avatar
I have heard alot of good things on the compstar rods, but I have never seen them used on a turbo setup making any numbers in this range (700/750ish) or greater. I'm leaning towards Compstars CR's, Pro-Grams splayed caps, ARP fasteners and Half-block fill. Anybody have any suggestions on the bearings ?
Old Nov 8, 2006 | 11:24 PM
SStrokerAce's Avatar
Compstars are good stuff.
Whoever is building the motor needs to pick out the bearings...
Bret
Old Nov 9, 2006 | 12:33 AM
Bret, when I get a little further with the motor build I think you should custom spec me a turbo cam to go with the LE3 heads....
Will I need to do anything special with oil pan ? I'm talking with Stef's right now about a 7qt with some custom items for the pan. The engine will be a 355 CI.
