Shaved heads vs Power tune
the next question is about the cam selection....ported and polished heads for an rpm range to 6400rpm stock bottom end I do not want a stahl...weekend bracket racing and daily driving, headers and possibly changing from 3.23 to 3.42 or 3.73 gears my goal is mid 12's or possibly the 11's. I also have a zex wet kit to 125hp but I dont really want to use it. My conclusion is the hot cam kit... but is there anything bigger that dosn't need a stahl? Sorry for the rambling but there is a method to my madness. thanks.
Far as compression cam plays into it but MANY of us run 11.5-12.0 on 93 octane.
No need to shave the heads to get 11.0, the stock gasket is .049, Mr. Gasket offers one .026 which should be just about right to get you 11.0.
Also do not bother bumping compression without doing headers it can create detonation problems.
I am sure you expected to hear do the stall and gears and thought you knew more but listen to someone who tried what you are talking about when I say it is a mistake to try to do the cam without the other stuff. Cam only I gained almost nothing, gave it the stall and rebuilt tranny and dropped to 87 octane tuning from 93 and gained .8 in the quarter, gears(2.93 to 3.42) were another .2, headers were .7. More recently with the current heads and cam I swapped from the 3.42s to 3.73s and gained another .1.
What is your reason for this and why?? Who told you this a is a good idea?
I would do FULL BOTLONs and at least a GEAR!
I highly suggest going with a stall also, but you can live and learn
You want to keep the revs low I would suggest something like the Crane 210/224, nearly everyone here will say it is too small BUT those who have tried it will rave about it. Also look at the little Lingenfelter cam 211/219.
