cam
Old Nov 11, 2006 | 11:16 PM
Revelation Z28's Avatar
Default cam
im gonna cam my car soon im gonna get the LT4 hotcam or something able to pass smog but bigger than the LT4 hc.
besides taking the waterpump, opti, timing cover, etc off, what would i need to take off with them?
do i need to put the cam in a certain way? or just in slowly while rotating so i dont hit the bearings. im at 148k and the engine runs strong. i dont plan on doing the cam bearings.
im gonna get a spring compressor to change the springs, how do they work? you set the bottom arms up in the exhaust ports for leverage?
Old Nov 11, 2006 | 11:49 PM
2fast97Z's Avatar
the compressor you are talking about is a pos it wouldnt even work on my springs and the heads were out of the car...i would find the one that a guy makes off of here and sells and it screws into the guide stud holes...now if you take the heads off and you get an air powered one like i have its a cinch
and your going to have to take your radiator out and you might have to take out your ac condensor im not completely positive
Old Nov 11, 2006 | 11:53 PM
i dont really want to take the ac condensor off. its gonna be a bitch to put back in and align.
i wish i didnt have to do the springs but the stock pressure on em are ****.
Old Nov 12, 2006 | 12:12 AM
the_merv's Avatar
Veteran: Air Force
Just be gentle and careful when putting the Camshaft in the Motor. The Condensor is easy to put back into place, you will just have to get the AC re-charged after.
Old Nov 12, 2006 | 12:23 AM
do i have to TDC cyl 1 after sliding in the cam?
or do i wait until im ready for the timing sprockets and opti?
thats gonna be a PITA
Old Nov 12, 2006 | 11:50 AM
the_merv's Avatar
Veteran: Air Force
Put the Dots touching each other when you put on the Timing Set. That will be #6 TDC.
Old Nov 12, 2006 | 01:45 PM
so just put the sprockets 6 o clock and 12 o clock with the chain on em, then put the opti on?
Old Nov 12, 2006 | 02:55 PM
the_merv's Avatar
Veteran: Air Force
Yup, dots touching..
 Michael S. Palmer
