lt4 cam spring
Old Nov 12, 2006 | 09:43 AM
compt/aclone's Avatar
Default lt4 cam spring
i found a great deal on a set of lt4 cam springs. but im putting a cc 503 or 305 cam in my car and im wondering if these springs will work or do i need to get diffrent ones. thanks
Old Nov 12, 2006 | 10:38 AM
sssalah's Avatar
Those springs will work with both cams only if 1.5 ratio rockers are used. The lift with 1.6 will be too much for them.
Old Nov 12, 2006 | 01:46 PM
Revelation Z28's Avatar
the LT4 hotcam set has 1.6 RR's, and the 503 is compareable size to it.
Old Nov 12, 2006 | 02:46 PM
yeah i know that the hot cam specs are with 1.6s but i think the 503 is with 1.5 i just didnt know how big of lift you could put on lt4 springs
Old Nov 13, 2006 | 05:09 AM
sssalah's Avatar
The 503 lift with 1.6 would be 0.536"/0.544", 305 is 0.544"/0.544". The LT4 springs were made for the stock LT4 cam which had a lift of 0.498" and they were just suitable for the 0.525" lift of the hotcam.
Old Nov 25, 2006 | 11:46 PM
phirepower's Avatar
Hey similar question guys, I have a mostly stock 97 lt1 formula, and i am looking to purchase a lt4 hot cam and the corresponding lt4 valve springs. My question is can the car run well with the stock 1.5 rr's or is it a requirement to move on to the 1.6's?
also are their other necessary mods needed for my lt1 to move well with the new cam and springs, thanks for the help. -D
Old Nov 26, 2006 | 10:10 AM
96capricemgr's Avatar
The LT4 springs are marginal for a HOT cam with 1.6s in LT1 heads due to the heavier LT1 valves. Do yourselves a favor and consider them ONLY for stock cam/1.6 applications and not for any cammed applications.
