What are you doing to your car this winter?
Old Nov 16, 2006 | 02:06 AM
  #41
Snyper's Avatar
355, single T76, ac/heat delete.
Old Nov 16, 2006 | 07:00 AM
  #42
UA-Plumber's Avatar
Originally Posted by PunishedU
In a way, I'm doing the best mod of all.
Im not spending a dime so I can hopefully save enough for a house which will lead to the best mod of all, a GARAGE, a glorious fricken garage. I can't wait.
I just did that mod. I bought a house last april by rockford and built a 24x28 shop behind it. That is why im goin easy on the mods this winter, lol
Old Nov 16, 2006 | 07:05 AM
  #43
LT1MAN's Avatar
garages are great, i unfortunately just had to give up my garage spot at my fathers house for a car cover because i moved into my own place, which is real close to downtown so i can get to work in 10 minutes, instead of an hour. so that frees up lots of gas money for mods.
i have my 383 and i am waiting on my stage 3 clutch to come in, i should be taking it to get installed week after next. after that i will be swapping my aluminum driveshaft out for a steel one and rebuilding my 10 bolt and beefing it up (see how long i can keep that thing together), i need more time to save up for a moser. hopefully be able to get on some slicks and get some track time in by feb.
Old Nov 16, 2006 | 07:22 AM
  #44
moserman's Avatar
yankin the 383, finishin up the mods i didnt have at the time i put the motor in! (ported heads, custom monster cam, afpr, ported intake, new fuel rails, an fittings and braided fuel lines, YES!!!)
Old Nov 16, 2006 | 10:03 AM
  #45
jd783's Avatar
rebuilding the t56,cai,longtubes,ewp,dbl roller timingchain,cc503 springs pushrods etc.,1.6 roller rockers,4.10's and ORY or true duals not sure which one yet oh and a mailorder tune. might do a little head work nothing extravagant. might run into spring but hopefully itll be a little faster when done
Old Nov 16, 2006 | 10:31 AM
  #46
Fire67's Avatar
I'm hopefully finishing my project. Which consists of 75# injectors, versa-fueler, finish the roll-bar, install Kirkey seats, install some of the interior, a/c&heat delete, Install the TH400, wire up the trans brake, install the adj. LCA's, install the slicks/skinny's, get it tuned, and try to do some racing before the heat comes back.
Then over the summer I will raise the boost to whatever I can get outta the blower and add methanol injection.
Old Nov 16, 2006 | 01:27 PM
  #47
Mortify's Avatar
I'm getting 4.10 gears, pacesetter LTs, 3" ORY, 1.6 RR and a xe230/236 (112LSA) cam, Short Throw Shifter, PCMForLess tune, and durring summer I will need new tires
Old Nov 16, 2006 | 04:59 PM
  #48
rob97ss's Avatar
Was going to do Kooks LT's,but my F*** opti just went,so my winter mod is going to be a Delteq......
Old Nov 16, 2006 | 05:07 PM
  #49
maybe2fast's Avatar
painting the intake black while its off
H4 conversion headlights
clear corners
Hot Cam
1.6 Hot Cam Kit rockers
LT4 Valve springs
Poly trans mount
LS1 driveshaft
New clutch
MSD blaster coil
MSD Cap and Rotor
New wires
Old Nov 16, 2006 | 08:45 PM
  #50
n2ocamaro's Avatar
Just finished a 6 point cage and I hope to have a 12 bolt before the track opens next spring.
Old Nov 16, 2006 | 08:48 PM
  #51
Out1aw's Avatar
Hope to have my new seats in at the very least! And then save up for a tranny and motor.
Old Nov 17, 2006 | 12:21 PM
  #52
UA-Plumber's Avatar
Sounds like a lot of projects!! lol
-Bryan
Old Nov 17, 2006 | 09:25 PM
  #53
C_Rules's Avatar
Originally Posted by UA-Plumber
If your not worried about Emissions, why not go with longtubes?
because my car is lowered and nyc streets will tear my long tubes and y tube up
Old Nov 18, 2006 | 12:01 AM
  #54
onephatZ28's Avatar
heads and comp cam and also going to install 4.10 gears.
Hope everything goes well.
Old Nov 18, 2006 | 12:02 AM
  #55
emerica4601's Avatar
From: king of prussia, pa (home) and williamsport, pa (school)
comp extreme 230/236
comp beehives
HSW 100 wet shot
tuned
Old Nov 18, 2006 | 12:20 AM
  #56
ChazGotAZ28's Avatar
125 wet shot N20, switching out the shorties for long tubes, LE3 package with LT4 heads and manifold custom grind cam, 58mm TB(already completed this part), short throw shifter probably some suspension stuff so that I can actually use all this power and not just break rear ends and do sweet burnouts. Pretty big winter actually now that I'm laying it all out. Oh and it doesn't snow in Tucson so I can drive it when I'm done.
