6.0" Rods, any clearance issues?
Old Nov 17, 2006 | 07:39 AM
Vicious95Z28's Avatar
Default 6.0" Rods, any clearance issues?
Got a factory crank and using 6" rods. Any grinding needed? I know I need pistons for 6" rods.
Old Nov 17, 2006 | 12:31 PM
siniSSter's Avatar
You should be fine. What kind of rods are you using? H-beam or "I"
Old Nov 17, 2006 | 12:35 PM
ulakovic22's Avatar
Will have problems with the rod bolts hitting stock windage tray. Nothing in terms of hitting the block though.
Old Nov 17, 2006 | 02:47 PM
Formula350's Avatar
Why would it hit the windage tray? The rods are only taller on the top, not the bottom. If he got a bigger stroked crank I could see how that would be the case.
Old Nov 17, 2006 | 03:10 PM
ulakovic22's Avatar
I'm running 6.0" Eagle H-beams and the dimensions of the rod are bigger in general. I had to remove my windage tray because the rod bolts were hitting it. It a fairly common problem. The stock rods are very small.
Old Nov 17, 2006 | 03:30 PM
Formula350's Avatar
Hmm, interesting.
"... And now you know!" (ABC?)
"and knowings half the battle!" (G.I. Joe)
Old Nov 17, 2006 | 04:06 PM
Rods are From Scat, clearance for stroker setups part#26000716
