nitrous on 100k
Old Nov 18, 2006 | 11:56 AM
lt1camarojoe's Avatar
Default nitrous on 100k
i have a 95 camaro with your usual intake, exhaust, hypertech tune, and a beefed up 4l60e i was considering putting on a dry 100 shot but my motor has a 100k on it. any thoughts?
Old Nov 18, 2006 | 12:30 PM
93 blackformy's Avatar
Why not wet?
Old Nov 18, 2006 | 12:34 PM
skatinjay27's Avatar
140k here and spray 100 shot wet. my fav. mod!
Old Nov 18, 2006 | 12:39 PM
camar0corey's Avatar
When I get finished installing my spray I will be close to 150k, going to be hitting it with a dry shot.
Look out for the hypertech tune though, you don't want your timing advanced, and need a safe A/F ratio.
Old Nov 18, 2006 | 12:45 PM
pddye's Avatar
i thought the hypertech advances the timing some. I'd take that off or you might run into some problems. Otherwise I have a 125 shot wet on my 130,xxx lt1 and i'm thinkin about running up to a 150 next season.
Old Nov 18, 2006 | 01:41 PM
what is the difference between a wet and dry is one better
Old Nov 18, 2006 | 02:12 PM
Formula350's Avatar
Dry is kinda how it sounds, dry. Wet is the ones that go in the injector hole and spray with the injectors.
At least I think that's it lol
Old Nov 18, 2006 | 02:30 PM
ChazGotAZ28's Avatar
^^You're thinking of a direct injection set up, wet shot's are tied into the fuel system with a fuel solenoid, dry shots are just sprayed into the intake usually throught the CAI and it goes from there.
Old Nov 18, 2006 | 03:03 PM
pddye's Avatar
the wet kits are just as easy as the dry to setup. Just screw the fuel line onto the fuel rail on the back passenger side of the fuel rail. Its a very simple install. I just screwed my nozzle into the intake elbow infront of the throttle body. I really like my zex wet kit b/c its very easy to install and does everything i want it to.
Old Nov 18, 2006 | 07:43 PM
ZEX-Z's Avatar
My brother has 132,000 miles on his Z28 convertable and with a tune for Nitrous and long tube headers and a hell of a tune up, 4.10's + a 175 shot he is easly in the 11's. His car is stock as hell. It handles the wet shot like a champ. He got the nitrous works setup and it works like a champ. Make sure if you can to have your car tuned for nitrous though. G-force does great nitous tunning so if you happen to get a few bucks together.. get it tuned so that you are not running lean on the bottle. Thats what takes your motor out. Running lean on nitrous. TRUST ME.
Old Nov 19, 2006 | 12:08 AM
Out1aw's Avatar
i have a buddy with a 3rd gen 350 car using a 150 wet shot with 212k on the clock and it runs like a dream.
Old Nov 19, 2006 | 01:44 AM
buffman's Avatar
my friend has over 160,000 miles on his LT1 caprice wagon and sprays a 150 wet shot.
Remember boys just like your women, wetter is better
Old Nov 19, 2006 | 04:48 PM
jakesz28's Avatar
I have a 94 z with 100,000 and spray a 150.
Old Nov 19, 2006 | 05:43 PM
Snyper's Avatar
i sprayed a 150 shot(about 6 bottles) on my first 93 trans am with 133k of abused miles. The car had cold plugs,header back exhaust,CAI and an MSD ignition..on 93 octane. Never had a problem.
Old Nov 19, 2006 | 08:43 PM
onephatZ28's Avatar
I have a 150 shot of NX, wet kit ,car has125k miles on it and runs real good ,
Old Nov 19, 2006 | 09:15 PM
4thgenz's Avatar
145K mi, 150 dry, stock everything cept for exhaust, good for 2.6 seconds on my et.
14.8@93 2.2 60ft n/a, et streets, 3.23 gears, LT's,
12.2@114 1.71 60ft 150 shot DRY
I LOVE IT!!!!
Old Nov 19, 2006 | 11:23 PM
BizZzatch350's Avatar
Moderator
So long as the cars been cared for its going to be fine. known plenty of people to spray high mile cars, putting a wet kit on mine, has a tad over 71K
Old Nov 19, 2006 | 11:58 PM
Snyper's Avatar
yeap NX is the only way to go.
