Stroker or 355?
I wouldnt go past 6200 on a Stock LT1 bottem, even with modified heads.
I dont know about 6700 RPMS on stock bearings... That might be a little to much.
my engine had 30,000 miles on it when i pulled it out..bearings looked fine...my car has 30,019 miles on it..it had 27,000 when i did the heads/cam..the bearings looked fine...i beat the **** out of it every day....single stock timing chain too.
Don't get hung up on dyno numbers either...they are way too easy to manipulate and don't mean too much...You'd laugh at the numbers I put down...Dynos are for tuning...the track is the judge...
--Alan
- 12.16:1 comp.
- Moded AFR 195cc LT4 heads
- Modified single plane intake(not a LT1 or LT4)
- 1250 cfm 4150 style TB
- DynaSpark opti
- Custom HR cam 288/292 adv. 259/263 @.050 110* LSA 110* Intake centerline
.640" int lift .620" exh lift
- Crane Pro series shaft mount rockers
- est. 617 HP and 502 lbs. ft. of TQ (close to within + or - 25 HP) at the flywheel
I make more HP than my old 383 and almost as much TQ all the way thru the rpm band.
- 12.16:1 comp.
- DynaSpark opti
You can make a 383 rev just as high as the 350 with proper parts for the job. It will spin up just about as fast too, again depending on your components used. The biggest thing is to match your components together for the job you want it to do.
-brand new block prepped by Dave Timmons
(Mopar Engines West)-scat forged steel crank
-scat forged rods probably I-beams
-JE pistons ( going for no more than 11.4-.5cr because of shitty gas in cali)
-clevite 77h bearings
-plasma moly file fit rings
-stock heads p&p fully(most likely) or 180cc CNC'd afr's (possibly)
-custom cam at least as large as the gm 847 or cc306 on most likely a 111-112lsa and matching springs
-1.6 nsa rr(not sure on brand yet)with 7/16" pushrods and hardened guideplates
-P&p stock intake
-58mm t.b.
-kooks stepped long tubes, no cats, coming out of true dual corsa's
*stock gearing in m6 tranny for now but 3.90 gears out back
*no a/c, no smog pump, and new k member so lets say 75lbs off the front end
I made 407 RWHP and 396 RWTQ with 195 AFR's and a small *** cam from Comp cams and an unported LT4 intake (with 60 miles on the motor). Now if I were to complimet the heads with a better cam and P&P the intake, and maybe open up the heads a little more... probaly be looking at 440 RWHP.
- Adv. Dur 286/294 int/exh
- @.050 246/254 int/exh
- 112* LSA
- 112* int centerline
- .592" lift int & exh with 1.6 ratio rockers
- I would recommend a set of Comp Cam lifter's # 875-16 to handle the RPM
This cam should make around 523 HP at 6800 rpm and 480 lb. ft. of TQ at 5200 rpm with the above mentioned 355. This cam is designed more for your road course racing for better power coming off of the corner's. It will also be a pretty good drag race combo for you. I was useing the above mentioned AFR 195 cc Eliminator heads for the build. I would not go with the 210 cc AFR's, as advised by AFR on my 355 combo.
- 112* LSA
Is this rear HP or flywheel HP???? and did'nt the eliminator heads jsut come out?
- 112* LSA
HP TQ
2000 127 334
2500 171 359
3000 214 375
3500 273 409
4000 339 425
4500 408 445
5000 430 476
5500 461 471
6000 494 464
6500 503 444
7000 520 415
7500 510 371
