Clearancing Issues 396 Vs 383
Old Nov 20, 2006 | 05:48 PM
mastermacbayter1's Avatar
Default Clearancing Issues 396 Vs 383
how bad are the clearancing problems on the sbc396 lt1's? are they a whole lot worse than a 383?
i can find a crank for one because its the 3.875stroke crank
i can find rods: 6.0"
the pistons are the hard part. if any one can find me a part number for a set that would be great. no nitrous so hypers would be great for my wallet. .030 over nothing over 12.0:1.
thanks in advance
Old Nov 20, 2006 | 08:41 PM
the_merv's Avatar
Look on Summit, what Heads are you using?
I have about 11.2:1 Comp. It has 6.1cc Pistons, 52.7cc Chambers, .039 Head Gaskets.
Old Nov 20, 2006 | 08:59 PM
96capricemgr's Avatar
3.875 crank with 6" rod puts the ring VERY high on the piston which is why you are having a hard time finding them.
IMO go 3.75 with 6". A 396 is much more about "mine is bigger than yours" than it is power.
Old Nov 20, 2006 | 09:14 PM
1SLO6's Avatar
from what i know on my build those psitons are custom made to order because of the longer stroke. yes the 396 is a mine is slighlty bigger than yours but if u got the cash y not spend it right?
Old Nov 20, 2006 | 09:45 PM
otherwhitemeat's Avatar
dude.... just call any piston company...they can custom make you whatever you need.
Old Nov 20, 2006 | 10:46 PM
lt1formula2000's Avatar
dude hes a cheap ***!
Old Nov 20, 2006 | 11:40 PM
95FbFormula's Avatar
Try here I was doing the same reasearch they have everything you need
http://www.cmotorsports.com/93-97-fbody/engine.html
here Are the pistons I was going to use they will make the CR 12.7 with that crank and 6" rods and a 0.39 head gasket.
SRP Forged Piston Set -5cc Valve Reliefs 4.030" bore x 3.875" stroke, for 6.00" Rod
