pinion gear question
Old Nov 26, 2006 | 12:56 AM
chameleongreen97ta's Avatar
Default pinion gear question
installing my new gears with a friend of mine and when i was at school he took the pinion gear out he used a hammer and smashed the first two threads on the end of the pinion gear together how can i fix this do i need to use a thread chaser or what do i need to do
Old Nov 26, 2006 | 09:49 AM
jakesz28's Avatar
You can use a tread file or a triangle file(60 degree angles are the same as most treads). With a tread file you have to find out how many threads per inch and match it up.
Old Nov 26, 2006 | 11:19 AM
9formula4's Avatar
where in iowa jake (sorry to hijack)
As for the question you can either file it or bet a tap and die set and rethread it to the right thread pattern.
