lloyd elliot and head gaskets
Old Nov 28, 2006 | 12:45 PM
ty97z's Avatar
Default lloyd elliot and head gaskets
i'm purchacing some le2 heads and i asked him what head gasket he recomends and he said use impala head gaskets.i didn't at the time ask why, but know i'm wondering? does he mean the 1996 impala ss head gaskets, what will it do raise comp. alittle? by the way mine is a 1997
Old Nov 28, 2006 | 01:39 PM
Ed Wright's Avatar
9-Second Club
They are thinner (.029" compressed), and will raise your compression. I use them on mine. Good gaskets.
Old Nov 28, 2006 | 02:03 PM
BlackScreaminMachine's Avatar
Internet Mechanic
I used LT4's they work too, but Lloyd and Bret are big on higher comp, N/A motors, LT1's can handle it with easy with a ***** on tune.
Ls1Bait's Avatar
How thick are fel-pros?
SStrokerAce's Avatar
Yes run the Imp or Mr Gasket gaskets. Tighter quench and more compression.
Bret
Old Nov 28, 2006 | 03:10 PM
Tony Shepherd's Avatar
.039
Old Nov 28, 2006 | 03:14 PM
T/A KID's Avatar
Bret my buddy nonosvt has some Ported heads that Lloyd just did the port work (He didn't do anything else, a local shop did the rest so I don't now?) with the LE2 cam on a rebuilt bottom end they used pistons that will give it 11:1 with the Felpros head gaskets, could we use the Impala or better yet the thinner Mr Gasket head gaskets and the compression would still be friendly. I suppose it would make it 10.4-10.5 or so???
Thanks, Ben
Old Nov 28, 2006 | 05:12 PM
maybe2fast's Avatar
kinda on topic. would a whole Felpro headgasket set fit an F-body app. Like if I were to order a felpro headgasket set for my 95 T/A would the Impala Headgasket set be the same except thinner headgaskets?
Old Nov 28, 2006 | 06:04 PM
Thanks, Ben
Ben,
It's 11:1 now with the .039-.041 Felpros? Going to the Impala gasket will help bump the compression ratio up more. That setup is designed for 11:1-11.5:1 easily. The thinner gaskets are not going to lower the compression they will raise it.
Bret
Old Nov 28, 2006 | 06:05 PM
The impala gasket is from GM. You would just use those gaskets rather than the FelPro Head Gaskets but every other gasket will work.
Bret
Old Nov 28, 2006 | 06:18 PM
T/A KID's Avatar
Opps my bad I actually ment to put 11.4-11.5, I was thinking about near stock compression at the time.
I may try to talk him into going with the Mr gasket head gaskets then
Old Nov 28, 2006 | 07:20 PM
96capricemgr's Avatar
Someone mentioned the LT4 gaskets and those are THICK much like the stock aluminum headed gaskets. Lets get all the "usual" gasket thicknesses in one post.
Stock aluminum gasket is .049
LT4 is .043 or .051 I am not sure which have seen both numbers repeatedly??????
FelPro is .039 decent choice for a zero decked block
"Impala" gaskets are actually on all the LT1 b-bodies and .029
Mr. Gasket is .026 PN 5716
Cometic has a bunch of sizes available thickness and bore but are picky about finish IMO best left to freshly machined blocks and heads, cost a lot but are reusable a big plus.
Stock deck height is usually in the neighborhood of .025, I have only measured 3 myself and they were .022-.026, you want quench to be ballpark .035 for most LT1 builds obviously on an untouched block even the thin Mr. Gasket .026 is unlikely to get you below .045 unless you have a freak block. This is why when doing heads and cam the vendors usually try to get you to go thin like the Impala or Mr. Gasket gaskets they get you as close as is practical without signifigant machining.
Old Nov 28, 2006 | 07:25 PM
dhdenney's Avatar
Thumbs up
Good thread!
Old Nov 28, 2006 | 07:42 PM
97LT1's Avatar
I agree, good to know.
Old Nov 28, 2006 | 08:07 PM
CNC Stew's Avatar
I'm using the Impala head gaskets also.
Old Nov 28, 2006 | 09:09 PM
daniel6718's Avatar
you cant you use impala gaskets or felpros for h/c n20?
should you go with cometic? and how think are they or can you get them diff thicknesses?
Old Nov 28, 2006 | 09:13 PM
burnzilla's Avatar
The Impala Gaskets are great for high compression and/or heads & cam packages, so I would imagine they would work nice with NO2.
Although I could be wrong.
Old Nov 28, 2006 | 09:42 PM
ToxicTA's Avatar
Every time you post I get smarter, thanks for the heads up info !!!
Old Nov 28, 2006 | 09:48 PM
Chevydomination's Avatar
I'm building a 355 with the LE3 h/c with n20, my engine block will be zero decked, which head gaskets would work?? "Bret"
Old Nov 28, 2006 | 10:08 PM
FelPro's are the all around standby for that. Cometics are nice, very nice and you can get them made in any size you need. I run them on my builds but I only do that if I know the surface finish of the block and heads.
Bret
