Who Is Best For a LT1 Custom Grind Cam?
Another vote for Joe if you can find him...I did talk to his head porter Eric Bradby (E.B. Porting) and he talks to Joe frequently...Erics number is 804-966-9077...I used Eric to do my heads and Joe for the cam and I couldn't be happier with the number I put up with the weenie cam...
--Alan
--Alan
Does bret give you a cam card or at least tell you what the cam is? I have heard he doesnt and it would suck for a tuner to try and tune it blind. That is why im not running one in my little stroker.
I will second Advanced Induction my whale has gone 11.9s on a stock shortblock, yes I pulled the belt and a little weight but also carry around a lot more weight and it is a stock unmolested shortblock.
I think the 10:1 and AFR are mistakes though and both will hold you back. The iron head LT1 was 10:1 and programmed for 87 octane. Nitrous likes compression so that was no reason to build it low.
If you heard that I don't then go back and smack the **** who told you that because he knows exactly dick.
Bret
Moderator
You got a lot of choices for suctom cams, Futral Motor Sports also has done some very very impresive cars.
Exactly, the main reason for that is a lot of people just use a cam similar in specs and go from there or just use that tune.
Originally Posted by SStrokerAce
FWIW a tuner doesn't need to know the cam specs
I agree Cam Motion is a good company.... All those LA boys down there use them. Meaux, Futral etc.... they are one big happy family down there.
Bret
Bret
