Stick with LT1 or go LS1?
Old Nov 30, 2006 | 05:32 PM
Greenfire's Avatar
Default Stick with LT1 or go LS1?
Since my car is down permenetly until I get the funds to do the motor, I'm asking around to see how hard it would be to convert my LT1 Firebird to an LS1? I'm fine with keeping my LT1 and getting the motor re-done.
But just how much of a pain in the *** is it to convert over to a LS1? Car is a auto and I already know my 3000 stall will have to be changed out for a LS1 stall.Thanks in advance.
Old Nov 30, 2006 | 05:40 PM
slick1851's Avatar
You will have to get a LS1 4L60E, and front cross member, with a bunch of other things
Pretty much find a wrecked car and take stuff from it so its all there.....
Old Nov 30, 2006 | 05:41 PM
slick1851's Avatar
Theres alot of bs things you need, searcha around its not to hard just take you time with it
Old Nov 30, 2006 | 05:46 PM
otherwhitemeat's Avatar
there is no point to change over.....power adders can fix anything!
Old Nov 30, 2006 | 05:57 PM
rasputin's Avatar
I bought my stock rebuilt to spec LT1 for 1 grand after I blew my motor, then used the money from selling the old motor to purchase a medium sized cam with all the necessary valvetrain to compliment my bolt on's + a couple hundred dollars. $2500 for 330-350rwhp or 4500-6 grand for an LS1 conversion. Its up to you, just wanted to let you know some alternatives.
Old Nov 30, 2006 | 06:03 PM
the_merv's Avatar
Veteran: Air Force
Yea, and that conversion is most likely a stock LS1. I was thinking about it when my old motor went out, but I was looking into building up a LQ9 to a 7.4L. That would be some crazy **** with a M6 in it..
Old Nov 30, 2006 | 06:30 PM
UA-Plumber's Avatar
That makes absolutely no sense.
Old Nov 30, 2006 | 06:36 PM
UA-Plumber's Avatar
My reason for going for it is as follows........
I like the front of the LT1 cars.
I like the LSx family of engines and their aftermarket
I dont like the 97-02 interiors (too fancy)
Best way to go is find a wrecked ls1 fbody
Old Dec 1, 2006 | 07:31 AM
Greenfire's Avatar
I think I'm going to forgo the LS1 swap. It's a bit more involved then I care to get into at this time. Any other ideas you may have please let me know. Thanks.
Old Dec 1, 2006 | 07:48 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Unless you get another harness you gotta snake out the whole deal from a wrecked car, personally if you want a LS1, get a LS1, LT1's are good motors but I have up after breakin too many things. The car spent more time on jack stands vs being on the pavement.
Old Dec 1, 2006 | 08:36 AM
the_merv's Avatar
Veteran: Air Force
It cost me about $1800 (including 4-bolt block) to re-build my LT1 from the ground up. I did it myself though..
Old Dec 1, 2006 | 08:52 AM
UA-Plumber's Avatar
LS1 motor or LS1 car?
Old Dec 1, 2006 | 09:30 AM
LT1MAN's Avatar
for the money and frustration you will spend on an LS1 swap you could do an LT1 stroker and have way more power and a brand new motor.
Old Dec 1, 2006 | 12:53 PM
Daez's Avatar
Well, if you think about it though.. Imagine buying a blown LS1.. building it for the same price as the LT1, and only having to spend an extra 1000(harness/blown block cost) Maybe another 500 for extra parts... I mean if you rebuild your lt1, you still have to pay for it to be taken out and put back in. I don't think a swap is much more expensive when you think about it.
Daez's Avatar
Not to mention that you could sell your lt1 if it's still running to cover the cost of the blown ls1 etc.
Old Dec 1, 2006 | 12:58 PM
emj2006's Avatar
I wouldnt go with an lsx swap. You might as well buy an ls1 car, theyre so cheap nowadays.
LT1nitrouZ's Avatar
LS1s suck.... that is all
Old Dec 1, 2006 | 01:02 PM
Ironxcross's Avatar
(depending on where you live)
Old Dec 1, 2006 | 03:17 PM
Internet Mechanic
For everything to work right you need it all.
Old Dec 1, 2006 | 03:29 PM
edlt1's Avatar
lt1 383 on spray
