400 horses
Old Dec 1, 2006 | 10:27 AM
Red96TA's Avatar
Default 400 horses
Hey guys i have a 96 ram air trans am ws6. All i have done so far is long tubes and a k&n filter. Any suggestions on how to get around 400 horses? Im planning on getting a cam for christmas but i dont know what cam or what i should get to go along with the cam? Any suggestions will be greatly appreciated! thanks guys!
Old Dec 1, 2006 | 10:30 AM
udlose99ta's Avatar
a good heads and cam kit will could get you there easy. Check out lloyd elliot. i think its eportworks.com
Old Dec 1, 2006 | 12:20 PM
LSWaaa?'s Avatar
Old Dec 1, 2006 | 01:16 PM
WhyHelloOfficer's Avatar
You can safely run a bottle on it and get pretty close to 400HP without sacrificing any daily driveability.
Keep in mind with choosing your cam -- you're going to need tuning and if you've got an auto a higher stall to work with the cam as well.
Exhaust, LT4 Hot Cam Kit, and 100 shot I'm running high 11s -- it all depends on how you want to get there.
Old Dec 1, 2006 | 01:28 PM
ulakovic22's Avatar
Spend the money on really good ported stock heads. Then you can run a smaller camshaft for driveability and juice it a little. Small cam will give you 330-350 and then you can throw 50-150 adjustable kit on there.
Old Dec 1, 2006 | 01:33 PM
Chevydomination's Avatar
Old Dec 1, 2006 | 01:35 PM
LT1_King's Avatar
you can't go wrong with a heads and cam. Lloyd Elliot has some great stuff and cheap.
Old Dec 2, 2006 | 08:48 AM
9formula4's Avatar
the Lloyd Elliot LE2 kit on stock bottom ends have been proven to put right at and a little over 400 hp
Old Dec 2, 2006 | 02:18 PM
steez's Avatar
set of well done stock ported heads...a good cam....cc305...ex 224/230....something along those lines all the bolt ons and maybe a shot of juice and a tune you should be good to go
