oil filter leak pt 2
Old Dec 8, 2006 | 07:10 PM
Revelation Z28's Avatar
still leaking
the bottom of the oil pan is damp, the bellhousing is damp with 1 little drip coming off of it, and the filter leaves a spot still
it stayed dry for 12 hrs or so after i tightened the cooler... but looks like im gonna have to take it off the block and replace the main O ring.
coolant wont spill out from taking it off right? im leaving the lines on.
Old Dec 8, 2006 | 07:26 PM
Sweetred95ta's Avatar
Originally Posted by aboatguy
That's too tight. All you have to do is to spin the filter until the gasket touches the base and the turn it about 3/4s of a turn. It still should turn pretty easily by hand.
Mike
Exactly. No filter wrenches needed to put the filter on.
Old Dec 14, 2006 | 09:17 AM
is this oil cooler seal a dry seal, or do i use oil or RTV on it? im going to change it today.
Old Dec 14, 2006 | 12:08 PM
TTT... in the process of putting it back.
do i use RTV or seal all oil/gas resistant all purpose sealant on the bottom of the seal where it does into the cooler?
