New Times
Old Dec 2, 2006 | 01:56 PM
ReD95LT1's Avatar
Default New Times
Mods:
pacesetter long tubes
hooker cat back
moroso cai
nitto dr's
Best run was a 13.7 @ 102, with a 2.3 60ft
Really couldnt get the tires hot, everytime i tried a burnout the car would just slide sideways? Temp was real cold outside i think in the high 40's, abnormal for AZ. Track prep wasnt the best, nobody was really hooking too well.
I was happy with my times i was atleast hoping for a 13.9
Cam will be coming soon, pretty sure im going with a cc305 220/230 114.
Do people usually do oil pumps with the swap? I know my pressure runs real low. About 18psi at idle, 35 at cruise, and not sure at WOT.
Old Dec 2, 2006 | 02:26 PM
Speed Density's Avatar
hashtagBMW
You should change out your DR's when you do your cam swap. Nittos are trash.
For what its worth...every .1 in the 60' is .2 in the 1/4.
Good Luck!
Tony.
Old Dec 2, 2006 | 02:30 PM
coldkillinTA's Avatar
yea get some better DR's and youll knock some tenths off quick! i went 13.43 @ 104 2.09 60' with just my pacesetters..
Old Dec 2, 2006 | 02:45 PM
ReD95LT1's Avatar
hmmm so by that calculation...
say i did a 1.8 60ft i would hit a 12.9?! that would be nice
what dr's do you reccomend?
Old Dec 2, 2006 | 03:29 PM
foggedz's Avatar
If your thinking about getting a CC305 cam you should by my used one. $75 for the CC305 on a 114lca, and CC springs and retaners that will support the extra lift. The cam has a few 1000mi on it, and my car went 11.70 at 115 cam only with this cam.
Old Dec 2, 2006 | 03:47 PM
ReD95LT1's Avatar
foggedz you have a pm
Old Dec 3, 2006 | 02:18 AM
hashtagBMW
255/60/15 Mickey Thompson Drag Radials.
Best out, even with my new setup im sticking to a DOT class and running a larger MT DR.
Tony.
Old Dec 3, 2006 | 04:10 PM
WhyHelloOfficer's Avatar
Tony.
I love my ET Street Radials. Definately a great investment
Old Dec 3, 2006 | 09:07 PM
rasputin's Avatar
Originally Posted by ReD95LT1
Mods:
hooker cat back
moroso cai
nitto dr's
Did you run at speedworld last night? I heard the track conditions were horrid so I wouldnt get too worked up about it.
You should check out AZFBA.com, we have our own message board with a lot of knowledgeable people from a various backgrounds and a nice amount of sponsors.
I would stay away from a 305, that things is small. You should probably do a hot cam kit if you want to do it for 500$. There are many more cams out there that are just as streetable but will make more power.
Old Dec 3, 2006 | 09:23 PM
ReD95LT1's Avatar
no i ran at speedworld on friday night. my friends were there on saturday and said they track was the same as friday. so im not too worried.
The 305 makes more power, from what i have been told, than the hotcam. And i cant pass up a deal on the cam,springs,retainers, and locks for $75 bucks!
Did you run at speedworld this weekend at all?
Old Dec 3, 2006 | 09:56 PM
rasputin's Avatar
no I am currently finishing up a few things on my new cam only setup, so negative but my friends were there. that is a good deal, make sure you do rockers too if the price is right! two people here in phx ran 12.4 @ 111 with that cam and some crazy driving, so lets hope for the best!
Old Dec 3, 2006 | 09:58 PM
ReD95LT1's Avatar
yeah, definitely going with 1.6 nsa rockers, pushrods, guideplates, 7/16 stud, all gaskets, not sure which timing chain, and msd cap and rotor.
ill be glad to be in mid 12's. its my daily driver so that is fine with me
Old Dec 3, 2006 | 10:17 PM
the_merv's Avatar
Veteran: Air Force
It's possible..mine is right about there.
Old Dec 3, 2006 | 10:25 PM
ReD95LT1's Avatar
Thats cool. I hope so, i think it would be cool to hit 12s.
Especially with all the ls1 owners thinking lt1s are worthless
Old Dec 3, 2006 | 11:23 PM
the_merv's Avatar
Veteran: Air Force
You an A4 or M6? Get that 60ft down and you will see a gain.
Old Dec 3, 2006 | 11:27 PM
ReD95LT1's Avatar
m6....
I have nitto drag radials, but i just couldnt seem to get a good enough burn out going to heat the tires well enough. I have NEVER hit a 60ft better than 2.2
Nobody could really hook that night, i was spinning all through 1st and somewhat through 2nd.
I was with my friend who has bolt ons and recently installed cam in his 98 ta ls1. His best was a 13.2 @ 111 with a 2.3 60ft
Cant wait to see what i run with the cam. May go once more before the cam swap to see if i can improve.
Old Dec 4, 2006 | 08:56 PM
UA-Plumber's Avatar
Is your car tuned?
Old Dec 5, 2006 | 12:05 AM
ReD95LT1's Avatar
No, not tuned yet. Waiting for the cam install and then ill be goin with a tune from either madz28 or pcm4less
Old Dec 5, 2006 | 06:51 AM
Formula_LT1's Avatar
Nitto's aren't worth a damn on the track. Good for street use thought.
I would invest in some ET Streets or better DR.
Old Dec 5, 2006 | 10:20 AM
ReD95LT1's Avatar
Yeah, so i have been told lol.
Ill have to keep them for now, since this cam swap will be taking most of my money for the time being.
