Difference(s) b/t LT1 vs. LT4
Old Dec 2, 2006 | 08:28 PM
eLTwerker's Avatar
Default Difference(s) b/t LT1 vs. LT4
I have the LT4 intake, hotcam and LT4 heads. So, can I buy an LT1 cam? What's the major differences b/t the two, and what parts can you mix and match??
Old Dec 2, 2006 | 09:28 PM
foggedz's Avatar
Basicly everything can mix or match. The blocks are the same, so any cam for a LTX based motor will work.
Old Dec 2, 2006 | 09:56 PM
burnzilla's Avatar
New camshaft design
Larger valves
Roller rocker arms
Revised Head design
Head Gaskets
Revised Piston Design
Positive-twist top piston rings
Fuel System
Intake Manifold
Roller timing chain
Specially machined crankshaft
Dual-mass front torsional damper
Nodular iron main bearing caps
Teflon rear crank seal
Head Flow #'s and Camshaft
http://www.grandsportregistry.com/lt1vslt4.htm
Old Dec 2, 2006 | 11:09 PM
eLTwerker's Avatar
After further review, my ride is an LT1 w/ LT4 mods. An LT4 "clone" I guess you could say. Here's a question. I want to get a bigger cam. Maybe comp's 236/242 .560/.580 112LSA. I will undoubtably have to spin the hell out of the engine to see max power. Being an LT1, I don't have dual front mass dampeners or the specially machined crankshaft. Not just in light of that, but is it not so great to push the engine to rpms possibly in excess of 6500. Obviously high rpms won't ever be really good for an engine. But will that big of a cam be too large for my setup?
P.S. sorry, this is a repeat of my thread started earlier.
Old Dec 2, 2006 | 11:15 PM
burnzilla's Avatar
The cam should work fine.
The problem lies in your crank bearings. If youre going to be pushing past 6000 rpms alot with that much power, youre going to really test them.
Old Dec 3, 2006 | 06:48 PM
blackdogz's Avatar
Go here - http://www.grandsportregistry.com/lt1vslt4.htm
