LS1 rear brake conversion help...
Old Dec 10, 2007 | 10:09 PM
CaribooLou's Avatar
Originally Posted by SmokedOutZ28
I was just happy with the fact my car wouldn't go rolling down a hill anymore.
HAHAHAHA and in the end isn't that all we really want??
Old Dec 11, 2007 | 07:50 PM
wrd1972's Avatar
Yeah, the LS1 parking brake compared to the LT1 parking brake is like comparing a 4 cylinder to a 8 cylinder engine, yeah that big a difference. The regular brakes I never saw much of an improvement but I am confident it was an improvement.
Old Dec 12, 2007 | 01:15 AM
zlover129's Avatar
wow, i didnt realize so many people had parking brake issues, ive never had issues and neither have any of my other friends who own LT1's
Old Dec 12, 2007 | 02:25 AM
96lt1m6's Avatar
the only problem i had was, the cable broke at the handle.
so i fixed it when i did the conversion
i think they break from the handle being yanked up.
Old Dec 12, 2007 | 02:26 PM
SmokedOutZ28's Avatar
yeah true... but I think the final straw was when i was at my g/f house and it rolled down the hill and almost took out a Z06. If it wasent for he mother working out in the yard it would of been a bad situation.
But now all thats over with now i encounter a new battle of how to run drag wheels without grinding the calipers.
Old Dec 12, 2007 | 03:21 PM
wrd1972's Avatar
Yep, thats why GM redesigned the rear brakes for 1998. The LT1 parking brake is super sensitive and requires precise adjutment to work at its best. Plus as the component wear it can not adapt without manual adjustment. It is just a crappy overly complicated design, the LS1 is just plain simple in design.
Look at the LT1 parking brake, it has tons of pieces parts. Look at the LS1 parking brake, only a few parts and normal wear outside of the shoes does not occur.
Old Dec 12, 2007 | 10:38 PM
Formula350's Avatar
Originally Posted by Paul Bell
I don't mean to hijack this thread....
I posted this on the brake section without an answer, you guys seem to know it.
What's the differance between rear LT1 F-body brakes and rear LS1 brakes?
.3 inches lol
When I replaced my rear, I went with a 99+ rear because the posi unit is better, but that's my main reason. 98+ all have the .3" bigger rears. At least the ones with disc do Sadly they still had drums *sigh*
I think they are cheaper too when you have to replace pads and rotors, but I'm not sure. I heard the fronts are that way.
Old Dec 12, 2007 | 11:39 PM
zlover129's Avatar
Originally Posted by Formula350
.3 inches lol
Didn't the Torsen and Auburn go back and forth between years? And what really makes one better? Some years the Auburn was the better option others it was the torsen. The Torsen is better for road courses and stuff with it being spring actuated with no clutch packs while the Auburn (though limited by size) was better for the strip with the clutch packs and all. I prefer the torsen simply because they supposedly don't wear out but dont really care too much
 Michael S. Palmer
Old Dec 13, 2007 | 04:51 PM
Paul- The main difference is the caliper location, Rotor size and thickness, and parking brake setup. All which seem to work better for some but not all.
The Caliper is located towards the front of the car unlike the lt1 where its located in the back, The rotor overall diameter is bigger & Thickness is greater. The parking brake on the LS1 style uses a "mini drum" setup it looks and works like a drum brake setup just not as big, the pads sit inside the rotor and when you pull the cable it pushes out on the cylinder that then pushes the pads up against the inside of the rotor.
