Cam selection
Old Dec 4, 2006 | 05:36 PM
95FbFormula's Avatar
Default Cam selection
I am stuck between 2 cams has anyone had experience with either I now alot of people use the 306 I will have all complementing bolt-ons and headwork done just want to find the cam that will make the most power for my set-up. I will be using around 3800+ stall
Comp Cams "Extreme" LT1 Camshaft, 230 / 236, .510 / .520 112 LSA,
Comp Cams "306" LT1 Camshaft, 230 / 244, .510 / .540 112 LSA
Old Dec 4, 2006 | 06:23 PM
rasputin's Avatar
306 for sure with that stall, but I have to say it, if you can afford a custom grind, do it because it is all in the set up and not in the specs on the cam. there is a lot more to it than that and I think other would agree. if you are doing a budget build, then the 306 for sure, but again, if you can afford it, it would be well worth it.
Old Dec 4, 2006 | 10:17 PM
well I was on the subject of getting a custome but dont know how much $$ they run I was thinking about a brett bauer or Joe o cam also how can I get ahold of them to ask about this if anyone knows.
Old Dec 5, 2006 | 11:08 AM
"bump"
Old Dec 5, 2006 | 12:51 PM
Sweetred95ta's Avatar
Old Dec 5, 2006 | 02:57 PM
dre2013's Avatar
custom cams run around $350+ from what ive heard. Out of the choices you have listed i would go cc306
Old Dec 5, 2006 | 03:15 PM
I was actually able to find Bret B's email so I send him a message and I will see how it goes I will probably be getting a custom if i can
Old Dec 5, 2006 | 05:20 PM
dre2013's Avatar
thats the way to go...also great lookin formula BTW..huge fan of the red/black
Old Dec 5, 2006 | 06:48 PM
DroppedM6Z's Avatar
For a stock head car i'd say the 230/236 576/571 XFI grind if you HAVE to buy a comp. Custom grind from bret or joe.O would be better
