LE3 350 guys
Comments?
I am most likely going to go LE2, good ported stock heads with larger valves, ported intake ect ect.
Do you guys think a fresh A4 with a trans go, deep pan, cooler, stall, will handle that with a 150 shot or should I play it safe and have a local guy I know build it (I trust him, he put one of his 400's in a 1,400hp Nova and its holding) and not worry about it.
I figure I will be making 540rwhp on the conserative side....
Something tells me it would blow the near stock 4L60E
Would Ford 30lb red top injectors work good or do I need more?
LE e-mailed me and he no longer sells cams on their own, only with the heads......
all well.I put up a WTB add for the LE2 on camz (more LT1 guys over there). He said with my stall and gears a CC 306 or GM 847 will work well....
I thought the LE3 was a tad larger then the 847????
I really think I will go custom grind....
Checked ou the cost of HSW's 42 pounders.... yeah I will pick some up
I called comp today and told them what I had and wanted. They told me 1.7 rockers, with the beehive springs (acting like that was holding me back) and did not want to spin the engine past 6200rpm said:
220/228 50 581/588
I told them I wanted super agressive and its with ported heads, 3200 stall, 4.10's... he said it was more agressive then the GM 847..... he did not ask many questions like what kind of power I am wanting or anything.....
