Lt1 Coolant Line Help
Old Dec 8, 2006 | 04:43 PM
MUSTANGBRKR02's Avatar
Default Lt1 Coolant Line Help
hey guy's I'm looking for the line that goes from the front head to head the front anyone have a part number or know where i can get one?
thanks ahead of time!
Old Dec 9, 2006 | 06:47 AM
anyone even know what im talking about??
Old Dec 9, 2006 | 08:01 AM
the_merv's Avatar
Veteran: Air Force
You are talking about the Steam line I assume.. custom make one, it will be cheaper, and work better.
Old Dec 9, 2006 | 08:22 AM
how would you do that with the custom fittings on the head?
Old Dec 9, 2006 | 08:27 AM
sssalah's Avatar
LT1 has the steam vent line connected to the back of the heads. LS1 has it in the front, and LS6 is bent differently. Which model you're asking about?
Old Dec 9, 2006 | 09:49 AM
the_merv's Avatar
Veteran: Air Force
He has a LS1 in the sig.. go into the LS1 forum, we have a different line on our Engines. They might be able to help you there.
Old Dec 9, 2006 | 04:31 PM
i have a lt1 also that is why i am here
Old Dec 9, 2006 | 05:59 PM
the_merv's Avatar
Veteran: Air Force
This is what I did with mine.
Old Dec 9, 2006 | 07:06 PM
what goes on the front ports then?
Old Dec 9, 2006 | 07:09 PM
the_merv's Avatar
Veteran: Air Force
Block them.
Old Dec 9, 2006 | 07:32 PM
so nothing goes there?
Old Dec 9, 2006 | 07:36 PM
the_merv's Avatar
Veteran: Air Force
No. The reason they are there is cause of the Casting. Since a Head is cast out of 1 mold, and them lines are on the same side, if you put only 1 side of the cast with a hole, it would end up opposite of each other when you put them on the Engine. I am suprised that they are out and not blocked. The fronts should be blocked.
Old Dec 9, 2006 | 07:43 PM
ahh thanks my first lt build and its not mine i wasn't there for the tear down so that is why i am so confused! thanks again! whenever i have a question you always seem to awnser it.
Old Dec 9, 2006 | 07:47 PM
the_merv's Avatar
Veteran: Air Force
I am still wonderin how they got them plugs out of the Heads. They are in there, really in there, and no need to be removed..
Old Dec 10, 2006 | 07:36 AM
they are new trick flow heads
Old Dec 10, 2006 | 10:58 AM
the_merv's Avatar
Veteran: Air Force
That's why..
Block the front 2 if plugs came with them.
