A/C & powersteering delete
Old Dec 9, 2006 | 05:12 PM
Armyman2445's Avatar
Default A/C & powersteering delete
Ok I know how to delete the A/C but on the power steering.....how did you do it? What did you plug? I know how I can do it but I want it to look clean.
Old Dec 9, 2006 | 05:55 PM
the_merv's Avatar
Veteran: Air Force
I would plug the inlet and outlet lines that go to the Pump. I have never done this before, no reason too. It would kinda suck with my 285/40's on the front.
Old Dec 9, 2006 | 09:51 PM
Razor_Blade's Avatar
You don't want to plug PS lines. It will be a little easier to turn if you connect them into a loop. It is best to get a manual rack, because it will have a more friendly ratio. That is a costly route though, since no fourth gens came with manual steering. The only ones available would be aftermarket.
Old Dec 9, 2006 | 10:11 PM
I was planning to get a manual rack later but I would like to move my car around for now and didnt want pluged hoses everywhere..
Old Dec 9, 2006 | 10:20 PM
the_merv's Avatar
Veteran: Air Force
I was thinking about that earlier..the loop instead of straight plugging them.
Old Dec 11, 2006 | 09:46 AM
LT14LIFE JT's Avatar
To clean it up, remove the A/C, PS, the entire bracket and relocate the alternator to the bottom. You can do a search for relocation brackets, but on my previous Z, I just used a collar and kept cutting it down until everything lined up. I also used the middle bolt in the water pump as an extra brace for the alternator. I fabbed up an old school "slide" type tensioner for it, but most people use the turnbuckle type.
Old Dec 11, 2006 | 10:06 AM
foggedz's Avatar
Def do not plug the power steering holes. It will be almost impossible to turn. If you plan on hooking the power steering back up in the future loop them. This will keep dirt out of the system, and keep the seals working properly. If you dont plan to hook it back up just leave the lines open. It will be easyest to steer with the lines left open, but it will probably tear up the seals inside the rack. The seals are only needed in you plan to run power steering again in the future, and do nothing when the power steering is disconnected.
Old Dec 11, 2006 | 10:22 AM
Taubr Unit's Avatar
I did exactely what LT1LIFE sais, i deleted everything and mounted my alt. lower on the pass side. Its sooooooooooo easy to work on my car now. Moved the battery to the rear, deleted my ABS. Its awsome.
Old Dec 11, 2006 | 10:43 AM
Jditlfm's Avatar
I like that elbow to the throttle body were did you get that?
Old Dec 11, 2006 | 11:16 AM
Taubr Unit's Avatar
its the black trick flow from summit.
Old Dec 11, 2006 | 02:48 PM
they also make a polished one
Old Dec 11, 2006 | 04:33 PM
Taubr Unit's Avatar
here my alt. bracket
Old Dec 11, 2006 | 04:57 PM
Exactly.
Old Dec 11, 2006 | 05:05 PM
93 4mula's Avatar
What did you mount the bottom to? Also how do you tighten your belt?
Old Dec 11, 2006 | 05:30 PM
Taubr Unit's Avatar
If you look close and look at the red bracket?? It bolts to the block with the 2 bolts you can see, then the bottom is a reg. alt. bracket with the "U" shape adjuster. I bought it off ebay for $20 new but had to modify it to make it longer cause our lt1 alternators are bigger then reg. chevy 350 ones. So i just extended it a extra inch or so and re-welded it back toghter. Then when you loosen the top bolt it will swing to adjust it. But when mine was all done it would twist just enough to make the belt to slip. So i added a turn buckle style i bought from Home Depot for $5 and bolted it to the front of the top bracket and the other end to the top bolt of the red bracket. Ill try to get updated pics for ya guys. All in all, i put 300 miles on my car and took it on a hour and a half road trip at 80mph cruising and i NEVER had 1 problem, so i know its proven to work!!!!
Old Dec 11, 2006 | 05:38 PM
93 4mula's Avatar
Cool. I am wanting to delete a/c and powersteering also when I put my motor back in.
Old Dec 11, 2006 | 05:40 PM
Taubr Unit's Avatar
it was all easy, just takes a little time to get it all adjusted perfect. power stearing was too easy, just take it all off and loop the lines toghter. ABS was easy too, should do that too. Makes making a intake easy as hell too!!
Old Dec 11, 2006 | 06:25 PM
Jditlfm's Avatar
i was really hoping it was plastic, damn aluminum intake elbows.
Old Dec 11, 2006 | 08:01 PM
the_merv's Avatar
Veteran: Air Force
That looks pretty good. I would have an extra one on the back of it going to the side of the Block.
Hey Taubr, where is the plug for your OPTI, or were you guys messing with something.
NM..I see you got the water pump off..
Did that today, that is how I noticed it.
By Brett Foote | 2026-06-04 05:00:17
