EGR Delete
Old Dec 11, 2006 | 12:57 PM
95FbFormula's Avatar
Default EGR Delete
While an am doing my H/C i decided to delete my EGR apart from removing the pipe and the valve. Do i just remove the solenoid to and plug the hole in the D-side of the intake manifold.
Old Dec 11, 2006 | 01:04 PM
the_merv's Avatar
Pretty much..and block off the spots on back of the Intake. You can clip the Pigtail for that also.
Old Dec 11, 2006 | 04:07 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Removing EGR and AIR is good to clean up the engine bay, also to lighten it up, but it doesnt help hp. good luck!!
Old Dec 11, 2006 | 05:45 PM
I know it doesnt help HP but I have it all off and i am to lazy to put somthing back on that dooesn't have to be lol. I also like the cleaner look I am trying to make my engine bay a clean as possible having only the nessesity in view thx for the help tho.
Old Dec 11, 2006 | 08:08 PM
the_merv's Avatar
It might not help HP, but most of the Cammed LTX's benefit without having it. I was running it for a while with my Hot Cam, the EGR was getting wrong readings, and it lead to a blown Head Gasket. I removed it, and put in the Racing LT's(non-emissions), and haven't had a problem since. Runs like a raped ape for what's in it.
Old Apr 17, 2007 | 09:57 PM
KuruptWS6spd's Avatar
On my 1993 LT1 what is really involved in tearing it off? I know what is the EGR stuff but on the intake right next to the EGR setup there is another huge deal with tubes going to it. It has a bunch of hoses (about the size of a garden hose) going from it that come up to the front of the motor and attach at a junction block of some sort. That part of the EGR system too? Anyone know of a writeup of everything to remove and tips to blocking stuff off?
Old Apr 17, 2007 | 10:10 PM
the_merv's Avatar
You have pics of all that.. I have an idea, but I want to see it to make sure..
Old Apr 17, 2007 | 10:28 PM
The black block in the lower right of the picture
Old Apr 17, 2007 | 11:09 PM
the_merv's Avatar
That's the A.I.R. junk, that's what I thought you were talking about, just to make sure I asked. Chuck that **** out...
Old Apr 17, 2007 | 11:10 PM
You just make your own block off plates for the A.I.R. and EGR holes on the back of the intake? What the A.I.R. stand for anyways? I know EGR is Exhaust gas recirculation
Old Apr 18, 2007 | 05:39 PM
To The Top! Anyone have a procedure or a picture of all the parts/lines that need to come off?
Old Apr 18, 2007 | 06:17 PM
the_merv's Avatar
You don't need block off plates for the AIR, just plug off the little connection on the Intake and you are good. Looks like everything else is gone out of it, you putting on LT's?
As far as the EGR, you take all the junk off of the back and put on block off plates there. Then you remove the little Solenoid for it, and plug off the Vacuum connection on the Intake that is right there.
Old Apr 18, 2007 | 07:27 PM
Midlength headers to be exact.
Old Apr 18, 2007 | 07:30 PM
the_merv's Avatar
Do they have the provisions for A.I.R. and EGR?
Old Apr 18, 2007 | 10:33 PM
Yeah, they are equipted for EGR.
Old Apr 19, 2007 | 12:11 AM
LT1powered89's Avatar
You can get block off plates for the EGR openings on the back of the intake on EBAY or you can just make your own. All you do is unbolt the solenoid and tubing and plug off the holes where they went. The computer will throw a code unless you have the EGR deleted out of the computer and in my case it still throws a quad driver code. Im currently researching how to get rid of that code.
Old Apr 19, 2007 | 07:05 AM
SnakeOiler's Avatar
You can change it in the PCM.
Old Apr 19, 2007 | 09:15 AM
the_merv's Avatar
Yea, block it off, and have it tuned out. If those Headers don't have the A.I.R. crap in them, they are going to look real nice on there.
