what do you think it'll run?
383 Golen Stroker
forged pistons and bottom end
advanced induction street/strip heads
Big Custom Cam (25x dur 108 lsa)
port matched intake manifold
58 mm throttle body
granatelli maf sensor
30# injectors
meziere electric h2o pump
msd blaster coil
taylor wires
pacesetter headers with straight pipes
dynomax bullets (strip)
CPT built 4l60e
4200 stall converter
Moser 12 bolt with 4.11's and locker
Weld Draglites with Hoosier QTP's
Spohn/BMR Suspension
brake proportioning valve
grant lightweight wheel
no a/c, cats, fog lights, egr, seats, carpet, heater box, airbags, abs system, etc...looking at 3300 lbs. race weight.
thanks for all your insite everyone!!
I'm running 10:1 compression, the GM 847, and the car weights 3520 with me in it (that is spare and rear seats removed)
My times at 1200ft elevation (DA was 1900 feet because of heat with nice dry air) were a best 11.45 @ 120.8 mph. 60 foot was a 1.62.
I think with decent launches low 11.1s and with a killer 1.50s or better 60 foot you should hit 11 ohs and hopefully an 10.9. But if your conditions are better you could add to that.
