Comp Springs for ported heads and stroker
Old Dec 13, 2006 | 11:50 PM
Superbeasst's Avatar
Default Comp Springs for ported heads and stroker
Are these good springs to use for an Lt1 stroker with the CC 306 and ported heads?
Comp 914
Outside Diameter of Outer Spring (in): 1.489 in.
Coil Bind Height (in): 1.100 in.
Damper Spring Included: No
Spring Rate (lbs/in): 367 lbs./in.
Inside Diameter of Outer Spring (in): 1.125 in.
Inside Diameter of Inner Spring (in): 0.819 in.
Old Dec 15, 2006 | 06:18 PM
96capricemgr's Avatar
Call Comp and ask, I tried to look up the cam card online but I got an error saying to call for specs. The cam card will include spring recommendations
Old Dec 17, 2006 | 12:49 PM
sssalah's Avatar
Seat load with these springs is 165 @ 1.800, a little bit too much for stock lifters. The recomended springs for the CC306 is 986, other spring like the 987 and 918 will work.
Old Jan 2, 2007 | 02:56 AM
freshmanit's Avatar
I got the 918's for mine.. they are very nice.
Old Jan 2, 2007 | 06:45 AM
BlackScreaminMachine's Avatar
Internet Mechanic
918's can more then handle a cc306, but you need NSA rockers.
Old Jan 2, 2007 | 07:48 AM
12345678910's Avatar
why do you need nsa rockers i am about to put a cam in my 95 z28 and didnt know that.
Old Jan 2, 2007 | 07:49 AM
i was going to use 918 springs and cc306 cam sorry forgot to put that up with the other one
Old Jan 2, 2007 | 09:57 AM
Internet Mechanic
has to do with the retainer and locks, the valve stem tip will not be high enough on a stock valve to be able to be aligned with the rocker. There are tabs that extend on each side past the roller tip and thats how a Self Aligning (SA) works, with NSA, you use guideplated and hardened pushrods.
Old Jan 2, 2007 | 05:03 PM
Matts94Z28's Avatar
Im running 918's, 10* lockd, and SA magnum roller tip rockers with a CC306 and it works out fine.
Old Jan 2, 2007 | 07:13 PM
Internet Mechanic
I have never owned Pro Mags SA but I have owned GMPP 1.6's SA and Pro Mag NSA, the GMPP had nothing to align them selves on there is no stem tip other then 1/8" above the retainers. The Tabs on the side would hit before the roller tip would hit the top of the valvestem,
Hey Matt94z28, post a pic of your rocker and spring, id like to see how Comp Cam has them done up.
Over all though NSA is more stable valvetrain wise when you get extreme lobe ramps, and high cam lift, it keeps it stable from 6k+ rpms
