no fire when starting!!! I just bought it too.
Old Dec 16, 2006 | 12:11 PM
matsgrn95z28's Avatar
Default no fire when starting!!! I just bought it too.
My 95 z28 has the LT1...runs great but I'm having problems with ignition firing. Recently I've had a battery replacement, excide 630 cca, and was told it wasn't getting fire bc there was not enough cold cranking amps. That was a quick fix now it doing it again, it turns over, all gauges seem normal (to my knowledge), except it will not fire. Fuel pump is working and everything seems to be fine bc I can hear it when I turn the key over....however I do not smell gas really bad any suggestions.
Old Dec 16, 2006 | 04:31 PM
roadtrip120's Avatar
Check this out, a little more info on the lt specific boards
http://mainstreamtopics.com/forums/i...p?showtopic=78
http://web.camaross.com/forums/showt...=injector+volt
Old Dec 16, 2006 | 06:46 PM
DroppedM6Z's Avatar
spark at coil?
Spark at plug?
ICM good?
turning they key all they way?.....lol j/k
