How to Fix Stall Wall?
Originally Posted by BlackScreaminMachine
Hey man I just got home
VSS Diagnostic Enable Min RPM
Mine was set at 3000, but of course change based on the stall, I had a 2800.
Originally Posted by 95FbFormula
Does every obd1 car experience this I was planning on a 3200 to 3600 stall but I don't want to lose my 2-1 downshift
And that was the only time I had an issue with this fix in the 2+ years I have had the high stall...
so it only effects the 2-1 auto downshift I would still be able to shift it my self. LOL i was only worred because that was 1 of my favorit things about the auto was the high rpm 2-1 downshift.
Well, I am not under the impression that ALL OBDI cars have this problem.
When I was doing testing SEVERAL years ago, I had a yank ST3500 and it would only cause a problem if I stalled it up before launch, leaving off idle was fine and actually produced the best 60's for my car.
Some have seen it with 3000 and others have not seen it till the 3800 range. it all depends.
The following users liked this post:
NewOrleansLT1 (01-23-2024)
it's a hit or miss kind of thing for OBD1 cars. It can happen and it cant. My converter is rated for around 3000ish. Stalls to around 3400 based on my datalogs. I've never had the stall Wall problem...
Some guys have stated the issue comes from flexing the output shaft on launch, loosing VSS signal etc. I would believe upping the min VSS diagnostic rpm could help, or you can completely turn it off in the switch table..
#32
From the tunercat refernce manual page 14:
Constant Type Calibration Table
The Constants Table is used to present calibration values that represent single values or calibration constants such as fuel cutoff RPM or injector flow rates.
#33
Originally Posted by 1SlowFormula
I always understood that VSS diagnostic RPM was just that a diangotic RPM setting, one of a couple that tell the computer to run the DTC32 Test, for the EGR... I don't see that helping or effecting this issue since it does not have any impact on the parameters around shifting...
I have no experience whether or not it is helpful, I was just relaying information that was presented in another thread. I've already made other necessary changes to my tune that have so far prevented any issues..
#36
Ed fixed mine(years ago) and it works perfectly
I spent thousands on transmission testing and verified it was in the PCM but could find no one to hack it up for me. Ed Stepped up to the plate and did it. he put his personal car together and tested code until he got it fixed.
IF you call him he may give you the converters to look for that cause this problem the most
I did go back to a OBD-II for the street. I like the 3rd gear select Lock up
#38
People think it's taboo or something to tell how to fix a problem. Especially this particular problem. Here's What I do and it works every time. Change the VSS Diagnostic Enable Min from 3000 to more than your converter flashes to and try that.It's under the ECM Constants table
